#15 | |
It also makes me begin to wonder if the timing is truly right. I set the crank pulley on 0 then aligned both cam marks with the marks on the backing plate. Now the thing is, does if matter if the the crank needs to be on 0 on the up stroke or the down stroke. Or is it the same either way?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car" 408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's -2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's - Two 87 turbo'd/targa top'd supras (*Under Construction*)
| Thread | Thread Starter | Forum | Replies | Last Post |
| 1988 Toyota Supra Turbo runs very rich need help | PhillyKorean | Non-Generation Specific Questions | 0 | 10-25-2008 03:28 PM |
| 1982 supra runs really rough when cold | tylertatum | Non-Generation Specific Questions | 0 | 10-04-2005 08:01 PM |
