Old 05-16-2007, 01:11 AM   #24
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
SHE RUNS! And pretty strong. Thank the lord. No more SES light. Did the knock sensor rewire mod without having to remove the starter and all is well now. Going to shim the wastegate a little tommorow and she how it does. Only running around 5psi right now. Also going to dial in the timing 1st.
Thanks!
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
