Old 05-15-2007, 06:29 PM   #23
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
Originally Posted by IHateHacks
Can't do it, you must remove the starter to access the rear knock sensor on an 87 turbo supra. Trust me. You can't even get the connector off with the starter bolted in.
Replace the knock sensors and let us know what happens.
I just got the plug off the other day when I rewired it without removing the starter. It wasnt hard. Im going to do the "KS rewire" mod 1st and see if that works before I pull the sensors.
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
