Old 05-14-2007, 04:33 PM   #15
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
Originally Posted by supradaddy0803
Ok I know this is gonna sound a bit silly but when I first got into mark 3's I did it and I have worked on cars since I was about 12. The thing was back like 1999 I didnt have internet access and I was stuck in the military in South Dakota with no reference to anything 7MGE so when doing the timing belt I got it 180 out. Sad thing is it still runs fine at idle but when you push the gas it will die real fast. Sounds funny but it will run beleive me I have seen old fords and chevy's run 180 out and they sound like crap. I am just saying this since you did the head gasket maybe check it because it shouldnt throw black smoke if you retard the throttle the computer shouldnt let it. I know you are running out of options might as well a shot in the dark it is a none interferance motor or so the toyota techs tell me so you wont bend anything. And by 180 out the cam marks were pointing down instead of up and the crank mark was pointing at them at the zero mark. But it is worth a try with what you are describing.
Thats weird but at this point Im willing to try anything. Ill see if I cant do it this afternoon.
It also makes me begin to wonder if the timing is truly right. I set the crank pulley on 0 then aligned both cam marks with the marks on the backing plate. Now the thing is, does if matter if the the crank needs to be on 0 on the up stroke or the down stroke. Or is it the same either way?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
