Old 05-15-2007, 01:34 AM   #19
IHateHacks
IHateHacks's Avatar
Theres no way the #1 piston was at bottom dead center when the crank pulley notch lined up with the 0 degree mark on the lower timing belt cover. Everytime the 0 degree mark lines up with the notch on the crank pulley, the #1 piston is on TDC. Its mechanically impossible for the piston to not be at TDC when the notch lines up. The crankshaft is keyed with the crank pulley so that it lines up with the 0 mark everytime the #1 piston is at TDC. Which TDC is another story, but I already went over this with you. Bottom line, when the crank pulley notch lines up with the 0 degree mark and the cam gear matchmarks line up with the notches in the inner timing belt cover, you are on TDC of the compression stroke and you can install the CPS as described in the TSRM. If the crank pulley notch lines up with the 0 degree mark and the cam gear matchmarks are 180 degrees to the notches in the inner timing belt cover then you are on TDC on the exhaust stroke. The #1 piston is at TDC everytime the crank pulley notch lines up with the 0 degree mark.
