Skip to content
Go Back   Toyota Supra Forums > Supra by Generation > MKIII Supra
Old 12-23-2022, 02:20 PM   #1
A70Gabe
A70Gabe is on a distinguished road
Default PLEASE HELP: 1JZ MK3 Overheating and Gauge Issues
This will be a long post because I need to provide a lot of context and data first. Questions at the very end.
I recently picked up an ‘89 Supra non-turbo 5spd (1JZ VVT-I and R154 swapped) and I may or may not have an overheating problem. The motor is an a ETCS motor (NOT ETCS-i). No idea what car it came from but it has an auto trans ECU. The car has the stock turbo, full bolt ons (intake, full exhaust, FMIC), a Koyo Racing aluminum radiator, Koyo high pressure rad cap, Mishimoto slim shroud, SPAL slim fans, a cooling plate (the cover that prevents the air from escaping around the radiator), and a low temp thermostat. The heater core has also been bypassed due to a faulty valve. It runs really strong without any issue (11psi) aside from the fact that when I cold start it it doesn't idle high like normal. It sits at warm idle rpm’s.
One of the previous owners took the entire gauge cluster apart to replace the gauge faces and all the needles are off. It also has a Glowshift digital coolant temp gauge and Autometer boost and oil pressure gauge. The oil pressure signal is coming from factory location and that means the oil pressure gauge in the cluster is no longer functional since it is disconnected. The coolant temp sensor location for the Glowshift gauge is in the middle of the upper radiator hose. Since the entire factory gauge cluster and the cheap aftermarket coolant temp gauge/sensor cant be trusted, the information is almost useless to me and I believe I am having an overheating issue that I can’t verify. I thought it might be best to replace all of that with a new quality coolant temp gauge/sensor and a virgin unopened factory gauge cluster. As far as I know these ecu’s cannot be extensively tuned and I will be forced to go stand-alone eventually so someone suggested I just get a display like an AEM CD7, Racepak, etc. I’d really really like to keep the interior fairly period correct with the original gauge cluster and some gauges on the A-pillar. I do also want all those sensors to be able to communicate with the stand-alone when I eventually get one so I can data log and set up fail safes (not an expert on wiring and electronics so I don’t even know if this is possible). I’ve seen the BTI gauge that combines everything in one but I find it would be too small and hard to read multiple things at a quick glance. I need to figure this part out first so I can actually have accurate data to determine whether or not I am even overheating. I know these engines are known for running fairly hot but I don’t know what the actual exact operating temperature is.
The factory gauge has never gotten into the red but the glowshift gauge has reached 230°F at 70mph. The faster you drive the hotter it gets. I think it could go higher if I kept driving but once I reached that temp a few times I got scared and had to cool it down by coasting until I come to a stop and sit there for a while. It seems to get hotter through increased load and RPM. Mainly RPM. It won’t really get hotter if you do a pull unless it’s a long pull (like 1st through 3rd or 2nd through 4th). The faster you go on the highway (higher cruising rpm) the hotter it gets but it will never overheat sitting still or at low speed. The fans are wired to a switch and always kept on unless the car is warming up. Sitting still or driving below 30mph will cause it to drop below operating temperature. The first thing that occurred to me was airflow but that cannot be the issue because it would be overheating at idle and low speed instead of at high speed unless the shroud and fans are becoming a restriction which I doubt. The heat stack is not ducted like a race car with seals and a huge hole in the hood but the way I see it, the average totally JZA70 had no problems with overheating under normal operation even with full bolt ons like this one, so why would mine overheat with the better VVT-i cooling system, high quality upgraded radiator/cap/fans, and a cooling plate? I know that the shroud and fans are slim and that the front mount can block some airflow but if in stock and lightly modded configuration it shouldn’t overheat, then I don’t see why it would overheat with all these cooling mods unless I have a problem like a bad water pump or blown head gasket. Somebody told me my rad/shroud/fan set up was trash and the only way to keep it cool is with a ChaseBays tucked rad/fan/shroud set up for an S14 which is way way thicker than the already thick one that I have. I don’t know much about Chasebays aside from that I believe their products are centered around dressing up engine bays for show cars. I would find it hard to believe that they make a better product (from a function standpoint) than Koyorad. Also, radiators lose a lot of efficiency when they get thicker and the Chasebays one is massive (3.5 inches). Somebody else suggested an electric water pump too. Although all that stuff may help, I see it as a bandaid, not fixing the problem since it should not be overheating at all in its current configuration. No matter how hot and humid it is outside and no matter how hot the coolant gets it will always drop below operating temp if I leave it sitting still at idle. This leads me to believe that my problem is circulation or lack of heat transfer, not airflow. Load can increase the temp but not as quickly as high rpm cruising does (then again, load is never sustained for several minutes). I tested this by recording the temp at certain speeds then slowing down and going the same rpm in 4th gear. The temp at 3000rpm in 4th gear was the same as the temp at 3000rpm in 5th gear.
Here is the data I collected with the fans ALWAYS running. Prior to testing I verified that there were no obstructions to airflow, no external leaks, and I had already driven the car around for 45 minutes to make sure it was fully warmed up and heat soaked. I tested on a flat straight highway with no traffic, holding constant speeds for miles at a time. I am in south Florida (80-83°F, 57% humidity, sea level, 10W-40 oil)
Around town: 175-185°F
50 mph 204-205°F
60mph 217-219°F
70mph 226-228°F
Oil pressure with coolant above 220°F: 18-19 psi
Oil pressure around town: 23-26psi
As you can see, it gets really hot with very minor increase in speed, and I’m pretty sure at 70mph+ it would’ve gone above 230 eventually if I hadn’t cooled it down. If the gauge is inaccurate I may not even be having a problem at all, so the first thing to do is fix the gauge problems and do some basic maintenance and testing (change the oil, flush the living hell out of the cooling system, verify that the heater core bypass was done correctly, full compression test/leak down test/cooling system pressure test/vacuum test/oil analysis/etc, check for clogged radiator, etc) then retest with accurate gauge/sensor.
My questions:
1. What is the proper operating temperature and oil pressure for this engine?
2. If this is indeed an overheating condition what do you think the cause may be?
3. What can I do about my gauge/sensor/stand-alone situation? Is it possible for me to go stand-alone and still retain the old school gauge set up I want? I will be doing the gauges first and stand-alone/harness later on down the line.
4. Is there a way for me to cleanly integrate aftermarket gauges into the factory cluster without it looking tacky? I ask because having an actual number for coolant temp instead of a vague needle is better and I’d like to avoid repeat gauges.
5. What kind of gauge mounting solutions are out there for our cars? Really want to keep this pristine interior looking pristine. I like the A-pillar pods I have but I’m curious what else is out there.
6. When I’m at idle or off throttle the boost gauge reads 0. I only ever see positive boost pressure and never vacuum. Could there be something wrong with that gauge or something?
7. What is the best location for me to put sensors (for accuracy) for oil press/temp, boost, and coolant temp? Is the current coolant temp sensor location not ideal?
8. What gauge clusters (what model year and turbo or non turbo) are compatible with my car that’ll give me accurate info and are plug and play?
9. Does anybody have any compatible gauge clusters for sale? what gauges/sensors do you recommend I get and with what features? I’d like everything to match and work in unison but the main thing is accuracy and functional features. I can think of tons of popular brands (aem, innovate, defi, autometer, apexi, blitz, etc) but don’t know what is good and what is not. I want tach, Speedo, fuel level, coolant temp, oil press/temp, wideband, vacuum/boost, and batt. voltage (voltage is least important)
10. Where can I find service info and parts for the 1JZ? I’m a former Toyota tech so I always had access to all the factory service info you could imagine through TIS, but that is only for the US market. The 1JZ never came to the North America in any vehicle so I have no access to that FSM. I also have always bought OEM parts for my IS300’s off of RockAuto (Denso electrical parts, Aisin timing belt/water pump kit, etc) since it is way cheaper that way. I know some parts between 1JZ and 2JZ interchange but not sure what.
Any and all input is appreciated, thank you for coming to my TED talk
A70Gabe is offline   Reply With Quote
Continued overheating, coolant spewing from radiator when warming up... Da6onesupra MKIII Supra 10 02-19-2011 05:42 AM
Need help! Overheating vbryanv MKIII Supra 18 08-19-2010 08:18 PM
Overheating issue, searches suggest BHG but i'm not convinced!!! poboy69 MKIII Supra 8 05-01-2009 05:38 PM
Random Overheating? MRice Non-Generation Specific Questions 10 03-24-2007 05:22 PM
overheating (again) sd88supra MKIII Supra 7 11-08-2006 03:50 AM
