#1 |
Just installed, well almost, new head unit with new amp. in my 1994 Supra Twin. Can't find a wiring diagram for the car and struck out contacting my local dealer. Actually, I can find a wiring diagram on various internet sites, but none have a diagram of the Fujitsu Ten head and Fujitsu Amp. Most indicate that an amp. in the vehicle is "unlikely". The Fujitsu has two plug ins for the antenna; a normal sized antenna connector and a smaller antenna connector that plugged directly into the rear of the old unit. Turn on the disc player and the antenna stays in; only engages when you turn the radio on.
I made sure the new head unit had a dedicated auto. antenna line. Here are the problems: 1. Can only find power to the wires going to the Radio Relay that sits atop the radio. All connections have been removed from the original unit. Do not have any positive reading on my meter when touching any of the wires on the connector I took out of the Fujitsu unit. Doesn't make any sense at all, but I've verified the meter is working and that I have a good ground before testing each input. Nothing. 2. How in the heck do you wire the power antenna using the existing wiring. I have a solid blue wire for the power antenna, but can't get the antenna to work. 3. Is there a company that sells an adapter for this particular unit? Have purchased a couple that were generic Toyota models that claimed to fit any Toyota; I can attest to one Toyota the adapters will not work with. I can find a battery wire and an ignition wire and crank the sound up, but I want everything to work properly. So I'm opened to any suggestions. Thank you. |
| Tags |
| power ant on new head |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Manual to Auto, Killswitch, Drive shaft | wayzhack | MKIII Supra | 7 | 10-13-2010 02:35 AM |
| auto to manual tranny swap | sd88supra | MKIII Supra | 10 | 11-24-2009 06:25 AM |
| Cobra Guys dissin Supra TT | MagicStick | MKIV Supra | 91 | 11-26-2007 03:06 AM |
| HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 3 | 08-13-2007 06:21 PM |
| Difficulty of changing tranny from auto to manual | vas85 | MKIII Supra | 2 | 06-03-2006 08:30 AM |
