Old 09-02-2011, 01:26 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by BradMD View Post
Ok so maybe 550hp is too much, i found out the stock TT can only go to around 400hp, and im not drag racing it or anything, at least not now. Just want to make it more powerful and fun to drive in the future. So im guessing say 450-500 is more suitable, i don't know really it all depends on how much i pay for the parts and whether it may be just a little bit more pricey for more power?
You also have been misinformed. If you're truly interested for whatever reason (given that you're an n/a owner) "the stock TT" can do a lot more than "400hp". That said, 'the stock ZR1 vette' can do 638hp...to me, that's just as irrelevant! The n/a MKIV and TT MKIV engines are completely different - with totally different heads, different pistons and a different ignition system!!! It seems that you arbitrarily want one to suddenly do the same hp as the other one. Why not evaluate what the n/a MKIV engine is capable of all on its own right, independent of what any other completely different engine/car/whatever can do? Also, if you want what the TT can do in horsepower, how are you going to stop all of that quickness once it gets going? With those pitiful n/a brakes? What about turning with the lousy n/a suspension and narrow 16" wheels? What will you do when the weaker n/a transmission or the weaker n/a differential gives up the goat?
Lastly, you never answered my question: What do you think of the n/a-T kit I linked to in my post above?
Life begins at 30psi.
Old 09-02-2011, 10:17 AM   #2
BradMD
BradMD is on a distinguished road
I only really want to know how much the GTE can make as I have heard it can do around 400hp but if more i may consider swapping the engine with a TT or buying a TT supra with the big brakes, abs ect. Other wise with a single turbo kit, i can fit bigger then UK brakes myself or find a used US/UK spec set. I also plan to fit aftermarket coilovers, and i have a set of 18" wider wheels already. I may swap the gearbox and drivetrain out of a wrecked TT or something if I don't get a TT supra. Regarding the single turbo kit, it is a bit pricey, also parts like the intercooler and other parts i can buy separatly with better specs, and reduce the price of the whole upgrade.
BradMD is offline   Reply With Quote
Old 09-02-2011, 03:07 PM   #3
pwpanas
Supra Owner
pwpanas's Avatar
1) You have to precisely match the intercooler size/"specs" to the turbo size. An intercooler that is too big will introduce additional lag. The intercooler in that Boost Logic kit is precisely matched to the turbo size, so anything with different specs won't work as well.
2) A cheap ebay intercooler is just that - a cheap intercooler. Most likely fitment will be poor, the kit won't be complete, and the poor-quality welds will split and/or leak boost.
With the oem twins, the highest hp I'm personally aware of (verified) for a 2jz-gte in an Mkiv Supra TT is 570hp (485rwhp). This was on brand-new turbos, a brand-new engine, bpu+++++, and dyno'd at sea level on a very cool day. I've actually heard of even higher levels by pro race teams who did extensive porting&polishing,etc. to the turbos, manifolds, intake & exhaust ports, etc. I agree that a 2jz-gte swap would be a great option for you, if you can find one with very low miles&hours.
Oh, and of course with an aftermarket turbo kit, fuel system, cams, ecu, etc., the oem 2jz-gte (bone-stock internals) is good to about 1200hp (1000rwhp+). The oem TT transmission and the oem TT diff can easily handle that hp level too.
single or twin? nathan ferguson MKIV Supra 6 02-28-2010 12:59 AM
Max Power from twin turbos 97SupraTT MKIV Supra 2 06-26-2009 04:55 PM
Twin TD07-25G "T-67" Turbos on a 1JZ or 2JZ *pics* kingtal0n MKIV Supra 1 03-20-2006 02:36 PM
