Old 06-21-2006, 04:44 PM   #1
f00g00
Default Code 25 and 26
Well to start I had this JDM engine installed here in the local scrapyard by the afghani's about 6 months ago (they said they don't like the taleban btw). I've allways had a slightly rough idle and lately the idle did the old up and down routine to 1800 down to norm constantly. I changed all the intake manifold gaskets except the ISC valve which I had to make myself as they company here didn't have one.
Well to make a long story short, none of the above fixed the problem. 25 and 26 started about a week ago and came on twice.
The attatched photo shows the culprits. They are my old injector packings that were installed by the taleban militia and as you can see the 3 on the bottom were pinched during installation. I showed them in the pic upside down to better show their distortion.
I put in the new packings and now it runs smooth and has a bit more power.
Old 06-21-2006, 06:13 PM   #2
theWeezL
theWeezL's Avatar
yep! that would be a problem.
____________
Old 06-25-2006, 06:31 AM   #3
thanks for posting up your results for future readers
Old 06-25-2006, 06:42 PM   #4
joel w
joel w's Avatar
Great thread...
Good title, some politics, a lot of self help, and a cure all in one post with pics..
<two thumbs up with a glof clap>
Old 06-25-2006, 08:38 PM   #5
jfunez
jfunez's Avatar
hey joel... you missed mentioning the good looking girl.....
my respect to supragirl.....
Old 06-25-2006, 10:29 PM   #6
joel w
joel w's Avatar
In algebra terms, Suzi is a given (goes without saying)...
And I was referring to the first post alone...
Old 06-26-2006, 03:32 AM   #7
jfunez
jfunez's Avatar
Originally Posted by joel williams
Great thread...
you refered to a GREAT THREAD.... I assumed by that you were speaking of the whole trhead not just the first post...
anyways.............
Old 10-04-2006, 10:05 PM   #8
Murd
*revives dead thread* My car started stuttering on acceleration and running rough on idle. So I did a diag, and pulled up codes 25-26. Running to rich, and too lean. Anyway I searched the board and found this post. Before I tear into this and replace the seals on the injectors, is there anything else I should do or check while I have em out?
Old 10-05-2006, 07:13 PM   #9
f00g00
What I did with my injectors while they were out was to power them open and use a can of carb cleaner while they were open to clean them out. You just have to take a spare plug with a couple of feet of wire and hook them up to a battery to energize the injector open. For the carb cleaner use the kind that has the straw and wrap a little tape on it so it seals at the injector opening and spray till it comes out in a good pattern, usually only takes a few seconds. And by al means use goggles when you do this so you don't get any in your eyes!
Also a faulty ox sensor might cause this too.
Old 10-06-2006, 07:58 AM   #10
Supra2NR
Supra2NR's Avatar
i dunt mean to jack the thread(which i seem to do a lot)
but im jus curious. code 25-26
do u mean to say running to rich OR to lean
not and
cuz i wanna know how do u get to run rich and lean at the same time
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
