Old 06-03-2012, 11:54 PM   #1
Wileyk24
Wileyk24 is on a distinguished road
Default Coolant Reservoir Overflowing
Hi guys,
Just did a major tune up on my 87 supra turbo. Plugs, wires, air filter, fuel filter, valve cover gaskets, etc. I even replaced all the air and coolant hoses in the car. I went with the ebay silicone hose kit which has 26 hoses in it. Overall I am happy with the quality of the hoses, leapyears ahead of my 25 plus year old factory hoses(so please don't flame over the ebay purchase). My car is bone stock.
So, with everything finished, my car keeps spitting coolant out of the overflow bottle. I have no signs of overheating(temperature guage is steady, stays in the middle, and never goes high or bounces around). I got a block test kit and tested my engine twice, both times no signs of a BHG.
So I assume I have to burp the system. I have heard all about it. Problem is when I try to burp the system I am not getting any air bubbles, just coolant pulsing slowly up and down and coming out of the radiator cap(when the cap is off). First I tried burping the car on my car ramps. Then I tried jacking the car even higher with my floor jack. Neither way seems to produce any difference in effect. Even did all of the above with the heater on full blast just in case.
What should I do? Car drives great, no smoke from my tailpipe, I am stumped.
Kris
Wileyk24 is offline   Reply With Quote
Old 06-04-2012, 12:58 AM   #2
Green7mgte
Supra Forum Moderator
test thermostat
if that passes
replace rad cap.
which ebay kit did you get ? that have some pretty decent knock offs floating around.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 06-04-2012, 02:04 AM   #3
Wileyk24
I bought the 26 piece Samco silicone hose kit.
http://www.ebay.com/itm/26PCS-SILICO...ht_1732wt_1163
I am more than pleased by the quality and fitment. Thanks for the advice, I will post a status when I get the chance to test. Probably not until the middle of the week. Going to be busy at work. Thanks again.
Kris
Old 06-04-2012, 12:33 PM   #4
interested!
Smile coolant reservoir overflowing
Originally Posted by Wileyk24 View Post
Hi guys,
Kris
Hi! Had the same problem! found the solution by COLD pressure testing the radiator cap , found to be releasing pressure too early and continuing to zero . This can be done by making a 4 way adapter to :COLD pressurise system / check pressure / release pressure and removes bubbles , this can be put into top heater hose , please see pictures . cured by adding shim to rad cap at sealing ring to increase length . set to release at around 13 PSI ,should shut off at around 10 PSI .Check by putting the OVERFLOW PIPE into a container of water and pressurise system with a foot pump attached to the shrader valve and check for bubbles ( releasing pressure ) leave to settle and watch gauge for bubble stop ( containing pressure) .By COLD testing the cap can be removed and refitted quickly after releasing pressure .This can be left in place to generally check the system for leaks .
ID:	4582   Click image for larger version
ID:	4583   Click image for larger version
Old 06-04-2012, 01:00 PM   #5
interested!
Default coolant overflow
Please see photo of shim position for message above. The small valve in the centre should be firm enough to contain pressure , BUT , weak enough to allow vacuum refilling of the system after shutdown - ensure all rubber seals are in good condition ( no nicks or wear grooves )
Old 06-04-2012, 08:44 PM   #6
Green7mgte
rather spend 5 bucks and get a new cap. lol Nice mod tho.. +1
Supra FAQ
Supra MKIII FAQ
Old 06-04-2012, 10:07 PM   #7
interested!
Smile coolant overflow
Hi! Thanks for your reply , I had bought and tried 5 new caps over many years to try and cure this problem -losing fluid without overheating - before I took this course to eventually cure it , now I am confident that I have the problem " sorted " - no fluid loss and no overheating problems when driving for hours in hot weather either! , -my answer to , it seems , a common problem.
Old 06-04-2012, 10:45 PM   #8
Green7mgte
Yea I had that problem once.. a new cap just solved it.. good mod if its recurring.
Supra FAQ
Supra MKIII FAQ
Old 06-07-2012, 05:56 PM   #9
Wileyk24
Hey,
Thanks for the reply's. I have had a new development. I didn't have time to drain the radiator down a little to remove the hose and test the thermostat. So I just went ahead and purchased a new radiator cap instead. I installed it last night, drove the car to work for the first time this morning and just as I was pulling in to work my car started OVERHEATING!! It went up and came back down in less than a minute or so.
Again, the system is full of fresh fluid, no leaks, and even no reservoir overflow since I put on the new radiator cap. No oil in fluid, no smoke from the exhaust...
I am seriously hoping that the overheating issue is my thermostat otherwise I am in for some serious repair work in my future.
Thoughts?
Kris
Old 06-08-2012, 11:45 AM   #10
Green7mgte
replace your thermostat.. perhaps look into a fail safe one.. were if it fails it just sticks open.. no overheat
Supra FAQ
Supra MKIII FAQ
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
Coolant on top of spark plugs suprajim MKIII Supra 3 03-24-2010 03:49 AM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
possible blown Head Gasket 2Fast2Furious MKIII Supra 37 12-23-2009 01:41 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
