Old 03-21-2012, 10:05 PM   #14
Originally Posted by ebang View Post
The coolant came out more water than coolant...must have been when I was topping it off i was mixing it too weak. Not a whole lot of coolant came out!
No worries there unless it's been a good bit below freezing temps there. Water by itself is a better heat exchanger than the components in coolant. The term "coolant" is a misnomer... it's a dielectric agent and a freeze temp modifier.
I got the valve covers and the gasket of course is shot...there are four bolts holding it on what do I use to remove these.
I believe it's a 10mm allen socket that you want. PROTIP: a 10mm long nut and a 10mm socket wors very well if you can't find an allen socket or they're over priced.
If the car would have overheated really badly why would have I lost all oil pressure and nothing but white smoke coming from the exhaust?
It could be two unrelated issues. White smoke is indicative of coolant entering the combustion chamber. A compression test may reveal it or pressurizing the coolant system may. This does not bode well for your HG though. Of course if your oil pump failed your pressure would fall to nothing and the extra friction could generate enough heat to warp things, blow the HG, causing the white smoke and crack the head allowing the gas from the combustion chamber to blow out the tensions wires.... Let's all take a moment to pray or wish or whatever it is you may do that this is not the case. This whole scenario is quite unlikely.... and a bit silly to even speculate on.
Blown Head Gasket Symptoms! Dejvid1785 MKIII FAQ 76 04-24-2011 07:59 PM
1988 supra 7mge engine blown what to do? 88supra7mge MKIII Supra 6 08-23-2010 05:22 PM
Update: Blown Head Gasket Snake Oil - 8 months later unkymurch Non-Generation Specific Questions 3 12-17-2008 09:35 PM
Blown line going to EGR Morty MKIII Supra 11 01-13-2008 12:42 PM
Blown Engine routeinet Non-Generation Specific Questions 12 12-30-2005 02:21 AM
