Old 05-06-2011, 08:38 AM   #1
italian89supra
italian89supra is on a distinguished road
Default coolant symptoms
i had my 89 supra 7mgte (about 2,000 miles) overheat recently in a different way. im new to all the supra terms and parts but the side coolant tank above the intercooler started spraying out of the end hose of this coolant tank near the cap, this caused the car to overheat then cool then overheat again since it was only smoking in the front of the car
once it was done spraying i still had about half of my coolant left (from full), and noticed there arent any leaks or holes
topped off the coolant and let the car run with the heater on
my thoughts are maybe the coolant was too full even though i was running with a full amount of coolant for a little over a month, or possible blown gasket symptoms i hope its nothing too bad
if anyone has experienced this problem or may know the reason and/or solution to the problem any help would be greatly appreciated
thanx to all that have helped in the past, present, and future
and i want to recommend anybody that hasnt clayed there supra with mother's clay kit does an amazing job, smooth and shiny based on experience, thanx again
HKS SSQV, cutout exhaust
italian89supra is offline   Reply With Quote
Old 05-06-2011, 08:54 AM   #2
87hilux7mge
87hilux7mge's Avatar
sounds like either a BHG or a clogged heater core to me.
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
Coolant plugs? scaggsj MKIII Supra 14 04-13-2010 12:00 AM
Coolant on top of spark plugs suprajim MKIII Supra 3 03-24-2010 03:49 AM
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Coolant leak issues D_Train MKIII Supra 1 03-15-2007 04:30 AM
