Old 04-22-2011, 10:09 PM   #20
good example of why you should bag your bolts with labels...
the washers should be for trans mount, to chassis.
the safty switch is located on the shifter of your auto, simply just disconnect it from the auto and plug it into your harness, and move it to the park position. i usually just cram it up with the clutch master cylinder.
and dam... if you got that tranny on without pulling the engine I AM impressed, because you have just reached a level of patience i will never get.
it is probly faster to pull the engine though, renting a cherry picker is not much, probly 30 bucks a day.
manual transmission frostburn MKIII Supra 9 08-18-2008 05:59 AM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
