#1 |
ill try that thanks.
but where should my negative battery terminal lead to?
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
The tail of the ground which goes to the block has its own boss right by the rear two bolts for the A/C compressor bracket; The other half grounds to the chassis on the wheel well.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
On my turbo I think one of the main earth leads went to the bolt that holds the steady bar onto the plenum, whether that was standard or just put there by the previous "technician" that's where I put it back & it works fine from there too...
quote "2 are from the engine harness, and the other are the positive and negative terminals from the battery." ------------------ There are 4 ring terminal earths that bolt to the lower plenum stud as cre said ,but just one point- the battery + cannot have an earth as that would = a dead short... the thick red batt.+ with a ring terminal, which is the only battery + with a ring in that area goes to the starter. (theres a smaller ign + with a spade connector that activates the solenoid too, don't forget that, I did!!!)
'89 MA70 Supra GT aero 3.0turbo JDM, Rebuilt motor, K&N intake, 3" stainless turbo-back. New turbo and braided line kit... '89 Honda NC27 400, NC23 cams, open pipe, PC36a shock & possibly Showa USD forks... '83 Yamaha 29R XJ750E-II, number 69 off the line, only runner in the country? Original except Koni shocks '95 Honda PC26 CB500R, Winter hack, hateful, trying to sell it I'm not paranoid, they really ARE after me!!!
#4 |
Didn't even notice that two were the battery wires... them missed that one was the positive.
The ground goes where I said previously... The batt goes to the starter (as MA70-3.0GT) said. The other two go to the one stud on the lower intake plenum which is not connected to the upper. Sometimes not having one to run out and have a look at is a pain....
#5 |
put the two grounds from the engine harness onto the lower intake plenum.
and i put positive on starter and negative on suport bar for upper intake plenum. all works fine thank you guys!
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Starter Removal question | OkieRA29 | MKIII Supra | 13 | 05-11-2010 12:08 AM |
| 89 Supra Starter Issue, anyone with pictures? | destro | MKIII Supra | 7 | 05-09-2010 09:13 AM |
| 90 mkIII starter connections | doodah | MKIII Supra | 1 | 11-11-2008 06:14 PM |
| How to quickly test starter | CyFi6 | MKIII Supra | 4 | 11-30-2007 01:57 AM |
| starter removel? | swied | MKIII Supra | 4 | 04-23-2007 04:50 AM |
