Old 06-25-2010, 06:38 PM   #11
Stanghunter
Stanghunter is on a distinguished road
Originally Posted by btwilson86 View Post
I'd probably start checking your plugs, wires, and timing (in that order) next. It's possible that your plugs could have been fouled, and the ECU running rich while in limp mode might have fouled them more. Also these cars are notorious for leaking oil into the plug valley, so you may have oil soaked plugs/wires.
When you check your timing, be sure to check your valve timing before you check your ignition timing.
Thanks again for the responses!!
Yes when they brought it over #5 and 6 plug holes where full of oil. I sucked it out with my brake bleeder then pulled the plugs and brake cleaned the holes out. I pulled all the cam cover bolts(all loose) and sprayed brake clean through the bolt holes and re-installed with locktite(blue). I did put 2 new plugs in.
I will put in 6 new plugs in next.
Are the plug wires shot after being soaked with oil? I cleaned them well but I know oil can break down and soak into rubber...maybe still shorting out a bit?? Just want to ask before I spend any more of their money....they already got soaked for $199 EACH for the KS's!
Stanghunter is offline   Reply With Quote
Old 06-26-2010, 06:26 AM   #12
btwilson86
Super Moderator
btwilson86's Avatar
Yeah, it is definitely possible that oil soaked wires can cause them to break down and start shorting out.
You may want to find a reasonably priced set of OEM style plug wires at an auto parts store if you're worried about spending too much money... That way you can swap the cheapo's in, test drive it, and if it still doesn't work there's not that much money out of pocket.
Old 06-26-2010, 08:59 AM   #13
Stanghunter
Well I ran it buy my dad and he wants to stay with genuine Toyota parts, so the wires are ordered. So Mr. Wilson thanks for all your help.....I wont bug you for awhile.....at least until late next week when the parts show up!
Thanks again for all your help!
Old 08-04-2010, 06:52 PM   #14
Mike87
Mike87 is on a distinguished road
Default Code 52 but all ok
Hi all, so what if u have a code 52 but everything seems to b fine. Runs good, sounds good. Thanks!
Mike87 is offline   Reply With Quote
Old 08-04-2010, 07:12 PM   #15
Green7mgte
Supra Forum Moderator
damn edit button..
reset your code bank
could be an old stored code.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 08-04-2010, 07:56 PM   #16
Mike87
Default Ks layman's terms
So for someone who is new to all this, can you explain a little what exactly a ks does. Any other items I should look for. Cleared bank, same 52 came back. Does knock mean a literal sound you can hear or is this a term for internal firing, etc? Thanks
Old 08-05-2010, 01:49 AM   #17
Travis89Turbo
Travis89Turbo's Avatar
The ks sense knock caused from to much timing it will the hear the knock or pinging and adjust the ignition timing accordingly. you changed the KS but did you do the re wire job?? I did mine a couple of days ago and it fixed the problem with out new knock sensor its very common on the supras. check the link out
http://www.supras.com/06/techcenter/display.php?QID=69
Old 11-28-2010, 01:29 AM   #18
mk3mike
mk3mike is on a distinguished road
this forum is awesome. i have learned everything i know about my car from u guys. i felt i needed to join to say thank you to everyone who takes the time to answer these questions.
mk3mike is offline   Reply With Quote
Well... Another code.. Cyto MKIII Supra 1 02-02-2010 12:21 AM
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
