Old 03-05-2010, 06:40 PM   #1
mtracing88
mtracing88 is on a distinguished road
Default code search
Where is the code search diagnostic port, and what type of code reader do I need for my 91 7mgte? Also where can I get one?
mtracing88 is offline   Reply With Quote
Old 03-06-2010, 12:43 AM   #2
MarkLinRacing
MarkLinRacing's Avatar
MarkLinRacing is on a distinguished road
Isn't it that thing in the engine bay? It's like a little black box by your fuse box that says diagnostic or something on it.
You just paper clip it and start the car and see how the CEL light flashes and then you get your code. Something like that?
MarkLinRacing is offline   Reply With Quote
Old 03-06-2010, 02:38 AM   #3
Green7mgte
Supra Forum Moderator
check the faq.. very first post in the Supra Faq
http://www.toyota-supra.info/forums/...iagnostic.html
this should answer all your questions.
this link is a bit more helpfull in understanding. It basically takes you to the same place as the link supragirl posted in the faq thread. but this is just more direct.
http://www.cygnusx1.net/Supra/TechTi...ror_codes.aspx
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
Old 03-06-2010, 06:54 PM   #4
I need to just copy the information from the cygnus page into a new entry to the MKIII FAQ. I should also copy my page on the diagnostic box functionality there too...
Old 03-23-2010, 08:03 PM   #5
mtracing88
Default fuel cut off
Wondering if I can avoid fuel cut off by upgrading my fuel pump only? What is the easiest way to stop fuel cut off? Least amount of $$.
Old 03-24-2010, 01:16 AM   #6
No, not really. The FPR will still work to maintain the same pressure as usual, there may be a bit of a bump, but not much and you shouldn't rely on it as it will be inconsistent. You can use an adjustable FPR along with a pump upgrade, but don't overdo it...
Green, I've copied that code sticky to the MKIII FAQ as well. I'll be adding info to it one of these days...
Old 03-24-2010, 05:09 AM   #7
Green7mgte
updates for the win.
havent been on much. work is kicking my butt these past couple weeks. I hate being sent outa state consistently
off topic sorry.
Supra FAQ
Supra MKIII FAQ
Well... Another code.. Cyto MKIII Supra 1 02-02-2010 12:21 AM
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
