Old 03-30-2009, 11:54 PM   #1
BrunoD
BrunoD is on a distinguished road
Default no spark out of ideas.
figured id try another forum since everyone on mine seems to be stumped. i have an 86.5 supra that i dropped a jdm 7mgte out of a 87-88 supra in. the swap came with engine wiring harness transmission computer and igniter. all i had to do was drop it in. well i did that. everything is connected and i have no spark. the coils tested good. the cam sensor tested good as well. i replaced the igniter and still no spark. someone have any ideas?
BrunoD is offline   Reply With Quote
Old 03-31-2009, 03:54 AM   #2
Vacationtime247
Test for voltage at the coil. If there is no voltage going in to the coil, there obviously won't be any spark coming out. Pull off the distributor cap, is the rotor in place?
Best way to test for spark is to pull out a spark plug, insert spark plug into mouth with plug wire still connected, have a friend turn over the engine. If you spit the spark plug out, you got spark. lol
VT247
Old 03-31-2009, 04:26 AM   #3
BrunoD
thats a great idea. except for the fact it doesnt have a distributor. but i did try the spark plug thing. was still in my mouth. still no spark. and there is power going to all 3 of the coils.
Old 03-31-2009, 07:59 AM   #4
Vacationtime247
The coils should get a signal from the computer telling them when to fire. Have you checked for signal when the engine is turning over?
VT247
Old 04-02-2009, 01:33 AM   #5
BrunoD
yea i checked it. im not getting anything. what i did was pulled off the 2 pin connector found my batt voltage then put my dvom lead into the other connector cranked it over and nothing.
Old 04-02-2009, 03:41 AM   #6
Vacationtime247
Default Hope I'm helping.....
What sensor tells the computer when to give the coils a signal on the motor you have installed? Is it a cam position sensor? A Crank sensor? Check for proper voltage out at that location with the engine turning over. Another thought is to make sure you have all your grounds. Computers and sensors don't act right without a good ground.
VT247
Old 04-02-2009, 05:32 PM   #7
BrunoD
ive checked all the grounds over and over. everything seems to be fine. im going to run another wire from the coilpack mounting plate straight to the battery and see if that does anything. and as for the sensor i belive its run off teh camshaft sensor.
Old 04-03-2009, 04:01 AM   #8
Vacationtime247
Again, check for signal coming out and going in to the cam sensor. If the cam sensor isn't sending a signal out (or getting proper voltage in), the computer can't send a signal to the coil. Also, have you checked the mass air flow sensor on the intake duct? A previous Supra I had wouldn't run without it being installed. It didn't run that great with it on either, so I sold it. Bought it at auction (not running) for $50. Sold it on eBay (running) for $600. Sure it was ragged out, but what did I care, I made some money and moved on to the next car. Might be that your engine has a MAP sensor, I don't know. But a few more things to think about checking. Is the knock sensor plugged in (if it has one)?
VT247
Old 04-04-2009, 05:00 AM   #9
BrunoD
what side of the engine would the knock sensors usually be on? drivers or passenger? ive got voltage going to the cps so i just need to isolate the signal wire from that and see if im getting voltage from that. i read somewhere else that a tps sensor would cause something like that so im gonna take a look at that too. heres the thing though. if a afm would cause no spark. maybe ive got the wrong one. jdm engine depot is where i got my swap. they forgot to send the afm with it so i had to call them up and they sent it out. but heres the thing. its really hard to get into the accordian hose to the turbo. and i mean like really hard. its just a little too big but i made it fit. any ideas?
Old 04-04-2009, 02:17 PM   #10
Vacationtime247
Not really sure what side the knock sensor would be on. I'm just throwing out ideas. The things I've mentioned are places I would focus on with any car having a no spark issue. Checking the TPS (Throttle Positioning Sensor) is a good idea as well, like you mentioned. When you say AFM, you're referring to the Air Flow Meter (or the Mass Air Flow, MAF) correct? If JDM sent you the incorrect AFM / MAF then cross reference with them the part # you have with the part your engine is supposed to be using. You mentioned that you're installing a JDM Turbo Motor into a 1986.5 Supra. Perhaps they sent you the AFM / MAF sensor for your year car, not the motor style like they should have. I wouldn't be suprised if there are variations in types of AFM / MAF sensors for Turbo's vs. N/A's and year manufactured.
VT247
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
need ideas theWeezL MKIII Supra 25 07-10-2006 06:23 AM
