Old 10-11-2010, 06:17 AM   #1
zby67
zby67's Avatar
zby67 is on a distinguished road
Default My new Project
a new toy of mine i picked up on my b-day beginning of this year. a 1987 supra i found a alone in a junk yard. 700 cant beat it lol. she has minimal rust just ware the spar sits. the exhaust is gone need a whole new system engine wont start oil in combustion chamber (spark plugs covered in oil) diver side tail light missing (toyota hates me they have none...) and front turn signal is missing. along with a peace missing for the passenger window to work. other then that all electronics work body in excellent condition sep faded paint (planing on getting a paint job anyway) nothing was touched under dash no wires sniped nothing (bones) interior looks great just needs to be cleaned (small tair in driver seat stitched it up. quick fix lol) engine bay is clean. needs a new radiator.
my plans are to gut my 1986.5 and put everything in one. (looks like ill be driving a beater with a heater till i have a complete supra -_-) send off the 7M-GE in the 86.5 to get rebuilt then put it in the 87. new paint job new calipers and a alot of other performance parts later and i have a nicer rid then i do now lol! and ill get to try out getting ride of the molding around the car on the 96.5! anyone know if there is a size difference in the tail lights between the 86.5 and 87?
(i got big plans for this new Supra!! the Supra dream is Not over yet!!)
new supra
86.5 with 87 in the back
1986.5 MA70 7M-GE
1987 MA70 7M-GE
zby67 is offline   Reply With Quote
Old 10-11-2010, 06:47 AM   #2
fantasma87
fantasma87's Avatar
look pretty decent for 700. it look that it still have a lot of potencial, like you said "the dream it just starting" Good luck . Q
ARMY STRONG !!
Old 10-12-2010, 04:34 AM   #3
zby67
zby67's Avatar
Thank you! yeah i thought it was over when i got t-boned 5 or so months ago but found this lovely lady and instant dream is back lol. ill be updating this with the parts and mods i want to do ^^
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-24-2010, 11:49 PM   #4
zby67
zby67's Avatar
alrigty so i got the engine out header off and now im able to tare about the engine though i have one question
what is this? side of engine ware starter is.
side of engine with header off
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 10-31-2010, 02:56 AM   #5
907mge
907mge's Avatar
Vaccuum canister for vsv that switches butterfly in the main section of the intake.
Old 10-31-2010, 09:47 PM   #6
zby67
zby67's Avatar
thank you! i thought it had something to do with that cause of all the little hoses running to it.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 09-13-2012, 04:25 AM   #7
zby67
zby67's Avatar
wow its been ages since i posted on here. go figure searching on how to do a manual conversion leads me back to the first supra forum i joined.
im always on TMT or SM sorry to bring this thread back from the dead.
whats new.
86.5 went to the yard after i snagged everything i needed from her and now in the proses of moving and wasnt going to move 2 cars.
i have put 1200 into my 7M's head new cams, shims, valves seals, 5 angle valve job, port match, bowl blend. total of close to 5k in parts most of witch are packed and not being used on this supra and engine. only about 1k in parts iv used in the 87.
for the 87 all thats been done is a new HG, ARP head studs, OBX headers, pacesetter exhaust, new gaskets, valve cover bolts, belts, hoses, NGK iridium spark plugs with bosch wires, along with a clean up and oil change. LEDs in the gauge cluster, tail lights, and Crystal Clear turn signals. along with 89+ white trim. new carrier bearing with new u-joints and fresh Diff oil.
still need to do list.
passenger Front wheel bearing
new tires/alignment
rear hatch weather strip
come up with vanity plates
and finish installing rear hatch interior
afew pics
Gauge cluster test run in 86.5 i just need 2 more LEDs i thought i bought the right amount.
yeah i know theres an ignition in the engine bay thats been removed
the 91 Supra im looking at buying is a turbo this car is just for DD.
these are pictures of my engine bay close to being finished. ill provide more up to date photos once im settled in the new house.
what do you guys think?
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Old 11-19-2012, 03:15 PM   #8
Looks great. I like your dual tipped muffler. The hot pink cam gear cover looks funny keep up the good work!
Old 01-28-2013, 05:20 AM   #9
zby67
zby67's Avatar
hehehe pop her hood and see pink!
thank you! glad you like it!
figure i would stop in and give some updates!
Updates:
clear curtasy door lights! (will be replaced with Green LED's)
trying to install down pipe and test pipe... (the down pipes will be modified to put the O2 sensor in the proper place and cut down to fit.
Video of start up and walk around! note i had to replace the license plate section so yes there is 2 Turbo badges on an N/A that when i take the car in to get painted ill be removing. sorry for shitty quality it was taken with my cell.
closer look at the engine bay.
this is just the header installed. O2 sensor is just sitting in the engine bay and turns out i hooked a vac hose up wrong so keep that in mind. oddly in order for her to stay running (with out holding the throttle) the distributor is all the way counter clockwise. if i turn it even a little clockwise she bogs and dies. im hoping that fixing the vac hose fixes this... the timing at the cams and crank are dead on at 0 i installed the distributor exactly how the TRSM says.
New calipers, rotors, Street tech brakes, SS brake lines installed. and the list of new parts to this car goes on lol. 2745$ spent on her and i still need to spend around 1500 to get her fully on the road. i have Euro folding mirrors on there way!
hope you enjoy my progress of my 87 Supra.
1986.5 MA70 7M-GE
1987 MA70 7M-GE
Need some serious help choosing a car for a new project. BAN WS6 Non-Generation Specific Questions 0 05-07-2009 04:08 AM
Help me with my SSTS project! Da1spa247 Non-Generation Specific Questions 0 09-25-2007 08:21 PM
