#1 |
7M POWAH! ;)
maybe the gasket has flogged out that goes between the water pipes and the back of the water pump
it has two 12mm nuts on it.. the water pipe travels under the exhaust manifold and to the back of the engine feeding the heater hoses ![]() you might be able to see that between the exhaust manifold and cps... not too sure have a look and let us know
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
#2 |
Both scenarios make sense. I no longer have a leak at the hose that was originally leaking (definite), but there is still some leakage behind and below that. Mr.Nickleye is right, there is a whole unit that the thermostat housing bolts to, and it may be up in there some where. But also I see coolant below that, so I don't know if Supra Girl may be right. Or Mr.Nicleye might be right and its just dripping down. (What a friggin mess) I think I need to go to a mechanic, but after being hustled so often, I dread the thought. I went to a guy yesterday who specializes in jap imports and he said he would do a pressure check and then let me see what is leaking. Does this sound like a good way to go?
Sincerely, James in NJ Oh, and by the way Mr.Nickleye, I had that drawing in hand when I walked into this guys office. I don't want him to think I'm an easy mark. |
#3 |
7M POWAH! ;)
lol more than likely we're talking bout the same thing
and good plan walkin in with the diagram hehe k here's all possible water leaks on that side of the engine ![]() ![]()
if you need anything explained more in detail i'll be happy to help out
#4 |
Thanks for a very helpful diagram Suprra Girl. You are right about j., the 90 degree pipe, thats the one that just blew on me and yeah, its a bit*h to get to. I think my leak is somewhere in that thermostat "rear" housing. Its a small leak, not like I'm blowin steam all the time. Just a drip, but definitely annoying not knowing what it is. Everything is packed so tight, I'm going to a mechanic and sit in his office till he comes in and shows me where the leak is before I say, "Yeah, go ahead and do the work". Otherwise I'm sure I'll be told I need new water pump or some other expensive fix. I have an N/A so it should make things a little easier.
Thanks, James in NJ |
#5 |
7M POWAH! ;)
well good luck... you could print out that image and take it with ya and tell them it can only be one of those lol
just eliminate the ones going to the turbo... it will go from bottom of back of thermostat housing to top rather than two pipes coming out and going to a turbo
#6 |
Dear Suprra Girl,
I do not have a Turbo. That should make it easier, huh? James in NJ |
#7 | |
7M POWAH! ;)
Dear Scruffy
read and thou shall see ![]() eliminate being the key word lol Quote:
| Thread | Thread Starter | Forum | Replies | Last Post |
| Want to buy a Supra, though having some problems finding one. | Cypherbku | MKIV Supra | 3 | 03-03-2009 01:45 AM |
| problems problems problems.... | 86SupraMan | MKIII Supra | 5 | 02-04-2008 04:28 PM |
| Starting problems and accleration problems! | alekjame22 | MKIII Supra | 6 | 03-17-2007 11:19 PM |
| Oil leak problems | adellicson | MKIII Supra | 1 | 03-04-2007 10:11 PM |
| problems, problems, and problems | tone loc | MKIII Supra | 6 | 09-06-2006 04:35 AM |
