Old 09-14-2007, 12:56 AM   #1
mk3ben.com
mk3ben.com is on a distinguished road
Angry wont go past 3000 rpms
i have a 89 7m-ge that when i push the throtle it wont go past 3000 rpms and i have no clue wat is wrong can anybody help me??
mk3ben.com is offline   Reply With Quote
Old 09-14-2007, 01:30 AM   #2
furia
furia is on a distinguished road
I did not have a supra for long, so I am not sure, but when I went to my mechanic to safety my car there was a supra there and he was saying it had a bad TPS sensor. He said it did not go past 3000 RPM because of that.
furia is offline   Reply With Quote
Old 09-14-2007, 03:25 AM   #3
redmaro
Check your codes.
MK3, Auto, Turbo.
Old 09-14-2007, 04:35 AM   #4
mk3ben.com
Originally Posted by redmaro
Check your codes.
how do i check my codes on this car i am mew with supras
Old 09-14-2007, 08:09 AM   #5
f00g00
http://www.cygnusx1.net/Supra/Librar...aspx?S=FI&P=23
Use any wire or get a spare plug with 2 male pins and make your own jumper like I did.
Old 09-17-2007, 04:08 AM   #6
jfunez
jfunez's Avatar
sounds like a bad mass air flow sensor...but check codes first.....
Old 09-22-2007, 07:52 PM   #7
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
When I was readjusting my TPS I did it wrong the first time. My RPMs would hit 3000 and drop immediately...after adjusting it properly with the OEM manual it worked normally again. The TPS could be it as "Furia" stated before.
Drag0na5h is offline   Reply With Quote
lex 550s boggin out near 3000 rpms? night-rider MKIII Supra 10 11-07-2008 01:03 AM
Supra makes wierd rattling noise after 3000 rpm on every gear HELP! 89MkiiiSupra MKIII Supra 5 08-20-2008 03:53 AM
Please help...93 N/A high RPMs uberbg MKIV Supra 5 11-12-2007 04:04 AM
1986.5 Idling at high RPMS Sasukevh MKIII Supra 2 06-14-2007 04:56 AM
used Japanise motor Rpms wont go past 3.5!! Help! Supra89redJapaniserebuiltEng. MKIII Supra 0 12-30-2004 10:04 PM
