Old 08-29-2007, 03:45 PM   #1
Burning Pyro
Burning Pyro is on a distinguished road
Default quick oil question.
yes i know its stupid, but how much oil does the 7mgte hold? i bought the car w/o a manual and havet invested in one yet, my buddy over filled her yesterday and i have oil down in the spark plug bay....again. he put in 4 quarts, but there may have been 5 total(he doesnt remember) and i wasnt watching him. sorry for the stupidty, but it would be nice for some help. thanks
also, what oil type should i be running? everyone that i know out here uses "mobil 1 10w-30 fully synthetic" my dad has built muscle cars snce he was a kid and ke knows cars. hes got a 06 gto with super charger and twin turbos, pretty nice, bout 800hp, anyways hes telling me to run like a 10w40 because its thicker, and hes sayin it should fix the oil pressure gauge problem.
Burning Pyro is offline   Reply With Quote
Old 08-29-2007, 09:28 PM   #2
Syris
Syris is on a distinguished road
The 7mgte will hold approximatly 5 qts. But to be on the safe side, when filling it up put in about 4-4.5 qts, run the engine, and then check it.
Oil in the spark plugs, check your valve cover gaskets for leaks.
The Oil pressure guage on many supra's will seem like they are reading 0 at idle, and its totally fine. Run the oil of your choice, but the general population of owners seem to run the Mobil 1 10w30 synthetic. I personally run Valvoline 10w30 synthetic.
Syris is offline   Reply With Quote
Old 08-31-2007, 02:17 AM   #3
mrnickleye
mrnickleye's Avatar
^^^ what he said.^^^
Old 08-31-2007, 04:30 AM   #4
88Tsupra
88Tsupra is on a distinguished road
im actually going to be running castrol synthetic 5w-30 with the OEM filter. just dont go cheap and make sure the oil you buy say API ceritfied and has a
ASE SM in the little ciricle on the container
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 09-01-2007, 12:14 PM   #5
IHateHacks
IHateHacks's Avatar
It ain't the valve cover gaskets leaking.
A turbo supra holds 5.5 quarts.
Oil pressure at hot idle should be 10psi not 0.
Old 09-01-2007, 05:05 PM   #6
Burning Pyro
well at any rate i fixed it. but i hate how ppl say on here that its normal for it to be at 0. thats not normal. ive worked on cars and i know how it works, my dad says the same. hes rebuilt muscle cars. at idle it should be at least 20psi. w/o pressure how is it going thru the system. i have a new gauge, but i messed up putting the sandiwch plate in, i think i was sent the wrong one, but im more than positive the stock gauge is not 100% functional. i recall one day dring and it shot up to 80, and then back to 0 with in 5 minutes. idk, just my thoguhts and throwing it out there, not trying to say anyone is wrong, but i dont think its right
1988 Turbo Supra w/ Targa Pearl White
3" Apex'i Exhaust from downpipe w/ 4"tip| K&N Intake Filter | HKS SSQV BOV | S-AFC II | 7mgte rebuild | ARP Head Studs | HKS MHG | t04E .63 trim turbo | 38mm Turbonetics waste gate | XS Power intercooler | Fluidyne radiator | 3" hardpiping/intercooler piping | all new belts | dual electric fans | tokico illuminas struts with eibach springs | think thats it for now....
Old 09-02-2007, 11:58 AM   #7
IHateHacks
IHateHacks's Avatar
Supras and most Jap cars use a low pressure high flow oil pump, much different from domestic manufacturerers and "mucle cars". Oil pressure should never exceed 40 psi on a MK3 supra, if it does, the relief valve or spring in the oil pump is bad. And at hot idle oil pressure should be "higher than 4.3psi" thats straight out of the TSRM. Don't forget that oil pressure changes with oil temperature. When I say hot idle, I mean oil temps above 190F degrees.
Front Strut Bar - Quick Question Grandavi MKIII Supra 6 09-25-2008 06:03 PM
Quick question 88ProjectSupra MKIII Supra 1 04-24-2008 11:56 PM
quick question need answered quickly switchblade Non-Generation Specific Questions 5 07-21-2007 12:47 AM
New here, quick question on possible lean issue adamsbomb MKIII Supra 6 02-13-2007 04:42 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
