Old 06-06-2007, 12:45 AM   #1
mk3000
mk3000 is on a distinguished road
Default loose lifters?
hello, im the proud owner of a 86.5 supra
i got the car about 2 months ago and i think just recently the lifter have loosened bcause when im driving theres an audible clicking/tapping sound, its not the engine tapping but i think more the valves.
first question is do the 7mge have hydralic lifters?
the car is my daily driver, so im worried the loose lifter are gonna ruin the valves, should i start fixing it right away or is it ok to drive it that way for a while?
thanks for taking the time.
mk3000 is offline   Reply With Quote
Old 06-07-2007, 01:37 PM   #2
Cool
it's the fuel injectors most likely
i don't know your background or what's been done to the car but I don't think you have any worries at this point
Old 06-07-2007, 04:39 PM   #3
mk3000
allright, theres a few supras at the local junk yard i could pull some injectors off of, but do you think i could run a few bottles of injector clearner through and possibly fix it?
Old 06-07-2007, 08:04 PM   #4
supramacist
supramacist's Avatar
Dude injector cleaner f_ucking blows chunks.
Ancient japanese secret here.
Automatic tranny fluid. Empty the tank after you get it running dump an entire qt of that into the tank and fill up with premium. I shit you not. It's the best injector and carbon cleaber. You'll smoke a bit but you will know it is because it is cleaning and lubricating everything within the fuels rail system.
Old 06-07-2007, 09:18 PM   #5
IHateHacks
IHateHacks's Avatar
Nope. Mechanical lifters meaning it has shims to adjust the valve clearance.
Old 06-07-2007, 10:19 PM   #6
mk3000
auto tranny fluid?
sounds sketchy to me but ive heard weirder things that end up true
(poring diesle fule into gas powered carberated cars)
i asked my dad, he has heard of this too so im gonna look some stuff up but has anyone else heard of this?
Old 06-08-2007, 11:07 AM   #7
Cool
i didnt say i thought the injectors were bad .
i meant i think the tapping you hear is your injectors
you can pull them off and have them cleaned and balanced
what a loose battery ground clamp does ghost88 Non-Generation Specific Questions 0 02-25-2009 04:42 AM
Loose shifter, missing coolant! XtreeX MKIII Supra 13 10-23-2006 07:13 PM
Need Help Loose Connector Dejvid1785 MKIII Supra 8 03-16-2006 02:10 AM
loose wires 87supraturbo19 MKIII Supra 10 01-19-2006 05:51 PM
loose exhaust bolts joel w MKIII Supra 4 10-10-2005 03:31 AM
