Old 07-30-2005, 02:45 PM   #10
daiagaru2
daiagaru2 is on a distinguished road
there is no point in putting larger injectors in your n/a mk3 unless you've really uped the displacement of the engine.reason being that an n/a motor delivers more power when the fuel mixture is more lean,adding bigger injectors will actually take power away from the engine making it run fat as too much fuel will be dumped as opposed to evenly igniting.if you want more power a turbo engine would be in order,just make sure you pick the right one.i personally run a 1jz-gte more power more reliability,however a good 7m-gte is in more order as it has egr valves and so on so that it can pass u.s emmisions.
daiagaru2 is offline   Reply With Quote
a few questions about the mkIV supra :D:D bad.boy MKIV Supra 4 09-17-2008 01:27 PM
Buying a Supra, I have some questions. Ungoliant MKIII Supra 7 12-23-2006 05:17 AM
Need your gus help- a few questions ravenmaster MKIII Supra 10 10-21-2006 09:59 PM
new here, few questions SoooopRa! MKIII Supra 6 08-29-2006 11:25 AM
newbie questions erik MKIII Supra 4 01-10-2006 11:37 AM
