Old 03-26-2007, 01:35 AM   #21
ethan12510
ethan12510 is on a distinguished road
i dont have a yellow connector in sight? I will post a pic. If i take it to a shop they can get it off right?
ethan12510 is offline   Reply With Quote
Old 03-26-2007, 01:40 AM   #22
IHateHacks
IHateHacks's Avatar
Yes, a shop will get it off but they will charge you probably an extra 2 hours of labor to remove it. They will probably just cut it off and replace it with a generic nut.
I'm interested in what your harness looks like.
Old 03-26-2007, 02:09 AM   #23
ethan12510
Smile
how do you post pics? Or can i email them to you? ALso i have one gray connector but i dont see another gray connector thats open with in the range of the o2 sensors wire. There is a open connector near the part that says 7MGTE on the passengers side? But it dosent reach? I will probly end up takeing it some where. Becuse i just got the car and it needs to be inspected. Will the inspection place, lets say hoffmans jiffylube just take the bolt off and then put a new one on? Will they know were to plug it in, becuse when i first opend my hood it wasnt pluges in to anything? so if some one could post a pic of where tro plug it in that would be great. And thanks for all the help!!!!!
Old 03-28-2007, 02:08 AM   #24
ethan12510
help? anybody
Old 03-28-2007, 08:57 PM   #25
ethan12510
i guess no one will help me? also what are the side affets of driving without an o2 sensor?
Old 03-29-2007, 12:03 AM   #26
OmeGa
OmeGa's Avatar
OmeGa is on a distinguished road
Your car may run rich, using too much gas and not enough air.
OmeGa is offline   Reply With Quote
Old 03-29-2007, 12:12 AM   #27
ethan12510
meaning horrible gase mileage? will running to rich hurt my car? thanks
Old 03-29-2007, 12:26 AM   #28
ddmcse
ddmcse's Avatar
Cool
it's better to run rich than to run lean . rich wastes gas and causes a ton of black smoke and soot
lean means not enough gas in the mixture and it will raise the running temp enough to do serious damage
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 03-29-2007, 12:30 AM   #29
ethan12510
Unhappy
so what ur saying that i will not do any damage to my engine if i drive with out an o2 sensor, I will just waste gas? Also could some one post a pic of where there o2 sensor plugs in. (mine came with it unpluged and a little cord with no female connector in reach)
Old 03-29-2007, 01:34 AM   #30
IHateHacks
IHateHacks's Avatar
I'm still too lazy to take a picture but I have an old one from like 2 years ago-
You see that yellow connector on the right? On top of the cam sensor and near the power steering res? That's where your O2 plugs into.
oxygen sensor 82 supra amigo MKII Supra 0 12-13-2008 03:28 PM
Oxygen sensor -wideband or narrowband? azerty MKIII Supra 1 05-06-2008 01:48 PM
oxygen sensor suprakid91 MKIII Supra 3 10-21-2007 04:41 PM
sub oxygen sensor sd88supra MKIII Supra 4 04-13-2007 01:20 PM
Oxygen Sensor questions RyDeFly MKIII Supra 14 02-11-2006 01:41 AM
