Old 07-07-2006, 01:28 AM   #1
Isphius
Isphius's Avatar
Clicking, Maybe a valve, rod knock, detonation, Things like that. As for boost, make sure you intercooler/air pipes arent leaking. Maybe hard to see sometimes, But check as best you can. And does your car smoke at all? could be a bad turbo...but i dont have much experience with toyota turbos. The valve cover gaskets arent hard to change, Just get the gaskets, take the throttle body off, and unscfrew em. Might as well change the plugs while your in there, Cause the TB blocks 2 of them.
Old 07-07-2006, 02:02 AM   #2
plati13
plati13 is on a distinguished road
car does not smoke and the tick does seem like a valve tick it sounds like air shoots through a tube so idk what it could be
plati13 is offline   Reply With Quote
Old 07-07-2006, 04:08 AM   #3
Isphius
Isphius's Avatar
hmm, Do you mean air shoots through a tube is the ticking sound? if not, Then id def say you have a boost leak. Replace all your intake tubing. And make sure your air bypass valve is holding boost, Just blow into it and see if it holds. And if you rule out all those things, You might need a new turbo. But i would doubt it if its not smoking or leaking oil.
Old 07-07-2006, 04:09 AM   #4
Isphius
Isphius's Avatar
is there anyway you can record the ticking noise? I forgot to ask that. That would be helpful
Want to buy a Supra, though having some problems finding one. Cypherbku MKIV Supra 3 03-03-2009 01:45 AM
problems problems problems.... 86SupraMan MKIII Supra 5 02-04-2008 04:28 PM
Starting problems and accleration problems! alekjame22 MKIII Supra 6 03-17-2007 11:19 PM
Oil leak problems adellicson MKIII Supra 1 03-04-2007 10:11 PM
problems, problems, and problems tone loc MKIII Supra 6 09-06-2006 04:35 AM
