Old 06-22-2006, 05:49 AM   #1
f00g00
Well scince you went to all that trouble.
I did it with them removed by getting some carb cleaner and put a little tape aroung the straw that came with the carb cleaner so when installed in the fuel inlet it had a good fit. The you need to open the injector so I had an injector plug from an old harness, hooked the wires to 12 volts and sprayed till the pattern was good once the injector was open.
A little advice though is wear some goggles or something to protect your eyes from getting flying debri or cleaner in them.
Now I use the method mrnickleye talked about here.
http://www.toyota-supra.info/forums/...ead.php?t=4658
Old 06-22-2006, 10:32 AM   #2
ddmcse
ddmcse's Avatar
Cool
there are places that will professionally clean and balance fuel injectors . i think for around $25 per injector
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 10-14-2006, 04:38 AM   #3
captwilddog
captwilddog is on a distinguished road
im not sure but i believe 12 volts is to much voltage on the injectors
captwilddog is offline   Reply With Quote
Old 03-11-2008, 11:19 AM   #4
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
yeah I would think that 12v would damage something
Supra Engine Powered Dragster
carfanatic89 is offline   Reply With Quote
Old 03-11-2008, 05:35 PM   #5
btwilson86
Super Moderator
btwilson86's Avatar
Correct voltage is around 1.5V to 3V... Using a single AA Battery works great.
Old 03-11-2008, 08:34 PM   #6
carfanatic89
Will It hurt the injector if you connect it backwards, I wouldn't think so, I think It just wouldn't open the injector.
Old 03-11-2008, 11:25 PM   #7
btwilson86
Super Moderator
btwilson86's Avatar
I'm not sure if it hurts it... When I did that to test my injectors, they just didn't open when the polarity was reversed. I haven't had any problems with them since I've checked them out, so I don't think it hurts them, but I wouldn't do it if at all possible (just in case it does).
A Few Q's on Turbo Injectors Chambers MKIII Supra 9 11-06-2007 03:26 AM
Fuel injectors redneck ricer MKIII Supra 0 06-15-2007 02:31 AM
Cleaning Intake & Injectors mrnickleye Supra FAQ 6 03-23-2007 04:26 AM
