Old 05-23-2013, 04:24 AM   #1
Serge
Serge is on a distinguished road
Default Chattering Noise
Hey Guys !
I have a chattering noise from my front suspension (88 supra auto....) Bushings are brand new, Ball Joints were good, Stabilizer Bar Bushing - good as well.....Any other ideas what that could be... ? Thank you !
Serge is offline   Reply With Quote
Old 05-23-2013, 01:05 PM   #2
MA70-3.0GT
MA70-3.0GT's Avatar
Hard to diagnose noises through just a description unfortunately, much easier to hear the sound in person but if it's just happening over bumps as suggested by your checking of ball joints/bushes etc perhaps you could check (listed in my personal order of most suspicion, ymmv) the anti roll bar's drop links for play, strut top mounts, steering joints, rack bushes, perhaps the brake pad anti-rattle shims, wheel bearings, wheel bolts and lastly, if all else fails, check that there's nothing else loose on the car that could be sounding like it's coming from the suspension but really isn't...
Wish I could be more specific, but that's the nature of the beast with distance diagnosis of noises I'm afraid. With any luck someone'll be nearby and be able to have a listen for you maybe?
Old 05-23-2013, 04:17 PM   #3
interested!
Default Chattering noise
Hi! , May be a good idea to check the steering rack rubbers for hardness and movement as well .
Old 05-23-2013, 06:21 PM   #4
MA70-3.0GT
MA70-3.0GT's Avatar
That's what I meant by rack bushes! Mine went bad after the power steering leaked & allowed the rack to move a good inch side to side, was quite scary under braking or trying to hold a line on rough roads!
Old 05-24-2013, 02:39 AM   #5
Serge
Thanks guys!
I'll check my rack bushings this weekend.... but my steering is sharp and working just fine.
The noise I have is quite random and I have it when I'm driving on obsoletely flat road.... it also sounds like a random drum noise....
Noise from the rear end? possibly a wheel?? winnas13 MKIV Supra 8 09-02-2011 12:55 PM
valve noise nailhead432 MKIII Supra 2 04-07-2010 03:48 PM
Wind noise near driver mirror BillW MKIII Supra 3 12-17-2009 05:09 AM
Terrible noise from the Drivebelt area 94TT MKIV Supra 2 12-04-2006 12:29 PM
help on knock knock noise Guest MKII Supra 3 05-31-2005 07:41 PM
