Old 04-30-2012, 09:56 PM   #1
2fast4u
2fast4u is on a distinguished road
Default mk3 supra differntial fluid
hello ive got a 1990 toyota supra turbo. i got a lsd differential in the back of the car and i was wondering whats the best fluid i can get for it at like autozone or oreily's or napa. i heard i need to use 90 weight gear oil and then add some thing else but please tell me the right thing before i ruin my differntial.
2 fast 4 u
2fast4u is offline   Reply With Quote
Old 04-30-2012, 11:56 PM   #2
I used redline in the last couple I had apart. The additive is a friction modifier which makes the fluid a little slicker so the clutch packs can slip a little easier when the wheels are turning at different rates. Add just a little, take it for a spin and add more if the diff feels tight or the outer wheel looses traction and chirps through turns. Any COMPETENT clerk at a parts store will be able to help you find it. I don't like buying oils with it already added when just changing fluid in an old diff as there may be too much.
Old 05-01-2012, 12:36 AM   #3
2fast4u
what can i use thats the best i dont want to ruin my diff and where can i get it because oreily sells some. please help changing it tommorow
2 fast 4 u
Old 05-01-2012, 02:55 AM   #4
2fast4u
Exclamation mk3 supra differntial fluid best one? help please
hello whats a good differntial fluid. i know i have to run 75weight 90 but whats a good brand full synthetics
like
royal purple
mobile one
lucas
or semi synthetics
or others . please help and on synthetics i dont have to add the additive right?
2 fast 4 u
Old 05-01-2012, 10:58 PM   #5
pandrade
pandrade is on a distinguished road
oh your asking what should be the base oil to use whith the redline adative cre recomended right? i used lucas heavy duty which worked fine but like cre said my outside tire still chirps a bit but only in wet weather running on my junk tires. iv never tryed any other oil brands like mobel or valvoline or royal purple so i wouldent be able to recomend any
cre your thoughts maby base oil to addative ratios.
1987 7m-gte R-154, SS braided clutch line, full 3in exshaust,aluminum radiator,full throttle gen 2 whith GM 3 inch mass air flow,13lbs flywheel, and more to come
pandrade is offline   Reply With Quote
Old 05-02-2012, 12:51 AM   #6
907mge
907mge's Avatar
Just read.
http://www.redlineoil.com/product.aspx?pid=133&pcid=4
Old 05-04-2012, 05:15 PM   #7
pandrade
iv never used it but if multiple people like it it must be good. all iv tryed is lucas
Old 05-07-2012, 01:57 AM   #8
People like 6th gen Celicas, Twinkies, seafoam and Lucas oil stabilizer... and they all suck. Popularity means NOTHING.
That said, I do like Redline. A good oil will never need additional additives, clutch packs and some automatic transmissions are an exception. See my previous post about clutch type LSDs and additives.
mk3 supra power steering fluid 2fast4u MKIII Supra 14 04-16-2012 01:29 PM
