Old 02-06-2012, 08:31 PM   #1
newtosupra
newtosupra is on a distinguished road
noob question ..... But does the starter cobtrol if the car will get spark or not?
newtosupra is offline   Reply With Quote
Old 02-06-2012, 08:47 PM   #2
The STA signal to the ECU affects it but is not solely responsible.
Old 02-06-2012, 08:49 PM   #3
newtosupra
So I would benifit from fetting a new starter? ...cause I have 350 a week to spend on the supra and I wanna get it reliable and everything before I start putting money into performance
Old 02-06-2012, 08:56 PM   #4
No.... test it. RTFM man. Test/inspect the following: starter STA pin at ECU while the engine is being cranked, igniter, ignition coil, plug wires, spark plugs and AFM... Test them all when the car is acting up and then again when it's warm and starting fine, then compare results.
Old 02-06-2012, 09:18 PM   #5
newtosupra
alright will do ... cause somene PMed me and said it may be my ecu and i was thing it was something with grounding...but im still gonna check evrything people tell me to first before i go and buy a new ecu
Old 02-06-2012, 09:39 PM   #6
The ECU is pretty solid. It's very often suggested as the cause of someone's problem but VERY rarely is that the case... I'm not saying you're not that one lucky person out of a hundred but until you've actually tested all the possible components you shouldn't be spending any money on it.... well, new spark plugs and wires are seldom a bad investment and they're cheap.
Old 02-06-2012, 09:42 PM   #7
newtosupra
Red face
alright another noob question under the hood of my supra theirs a little box looking thing that says diagnosis ... do u know what tool i use to actually use the diagnosis feature on the car ?
Old 02-06-2012, 10:01 PM   #8
So all this time you haven't even checked for diagnostic codes? I covered that in my FIRST reply to you.
And you mean "there's" as in "there is" not "theirs" as in "they" possessive with an "s" added for flavor. Sorry, the grammar thing just kills me.
Tags
issue, spark
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
