Old 08-23-2011, 09:32 PM   #1
bignag06
bignag06's Avatar
bignag06 is on a distinguished road
Default error code 42 issues
i ran the diagnostic on my 1988 supra and got the error code 42. my question is will that cause the car to lose power and cause it to almost turn off when letting go off the brake to start driving? if not what else could it be? appreciate the help and thanks in advanced!!
bignag06 is offline   Reply With Quote
Old 08-29-2011, 07:56 PM   #2
You'll get more response if you post in the MKIII Supra sub-forum. I'll move this thread there for you.
Old 08-30-2011, 05:29 AM   #3
bignag06
bignag06's Avatar
thanks!!! i also have a code 11 which is a momentary interruption of power supply in ecu. how do i check if its the wires or the ecu itself?
Old 08-30-2011, 01:50 PM   #4
Sonyps307
For code 42 does ur speedo work if not then the speedo cable coming form the transmission is broken. so the speedo sensor is not getting a signal. If it does work then the speed sensor is bad. I don't know if that is causing that problem or not. Now for the code 11 check the main grounds for the ecu. they r 2 brown and 2 white wires that r bolted to the intake right above the starter. Just try cleaning them first and erase the code to see if it comes back again later.
Check out this site
http://www.mkiiisupra.net/joomla/ind...d=24&Itemid=29
Old 08-30-2011, 01:51 PM   #5
MA70-3.0GT
MA70-3.0GT's Avatar
Welcome, firstly the TSRM http://www.cygnusx1.net/Supra/Librar...ection=FI&P=23 which is your best friend when it comes to the Mk3 doesnt seem to list a code 11. The code 42 I believe wouldnt cause the engine to stall or nearly stall although I'd appreciate if someone could back me up/correct me on that.
Assuming there is an interruption of ECU power supply, that would cause the car to cut out. Perhaps you could check your fusible link & other EFI related fuses first off (bearing in mind that old fuses can & do fracture without actually melting, causing intermittent contact) and then try clearing the codes to see what comes up then.
Hopefully the link will provide more than enough to be going on with for now, before I go can I just point out that with certain issues it helps to know if we're talking turbo or n/a.
Old 08-31-2011, 05:29 AM   #6
bignag06
bignag06's Avatar
sony: my speedo does work but it bounces around but still staying with the actual speed. i'll check that out thanks for the info.
ma70: thanks for the welcome. according to a website that deals with obd1 codes. code 11 only comes up on cars up to 1991. thanks for the tips, i will try those things out and see what happens. btw, my supra is n/a.
Old 08-31-2011, 06:48 PM   #7
An erratic speed signal is as bad as not speed signal.
You're not going to find code 11 in any MKIII after '88. It is the code for "momentary interruption in power +B (and/or +B1)" and can also be caused as mentioned by poor grounding at the head.
http://supra.co.nz/87tsrm/EFI/efi30.htm
New Car New Issues localrager MKIV Supra 5 09-19-2010 11:59 PM
Cold start issues??? Stanghunter MKIII Supra 1 07-19-2010 08:48 PM
Transmission Issues xpurplepandasx MKII Supra 6 08-23-2007 02:12 AM
fuel injector issues doc1 Non-Generation Specific Questions 5 03-30-2007 04:08 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
