Old 03-25-2011, 02:22 AM   #1
El_supracabra
El_supracabra is on a distinguished road
Default how does milling the cylinder head affect the valve timing??
I milled .020" off of my cylinder head, is this going to throw off my valve timing? do i need adjustable cam gears? please advise.
86.5 mk3 7mge non turbo
86.5 Supra NA: milled head .020, decked block .007, .5mm+ pistons, port & polished intake manifold and cyl head,OBX header, 3-angle, cold air intake, Cometic MLS HG. ALL NATURAL!
CHEVROLET- Cracked Heads, Every Valve Rattles, Oil Leaks Every Time
FORD- Flipped Over, Rebuilt Dodge
DODGE- Dirty Old Dust Gathering Engine
I'd rather drive a Toyota, than push a ford.
El_supracabra is offline   Reply With Quote
Old 03-25-2011, 03:04 AM   #2
907mge
907mge's Avatar
The 7mge is a non interferance motor to begin with, so no. The only thing it will do is raise the compression a bit.
Old 03-25-2011, 07:24 AM   #3
The teeth on the timing belt most likely would not perfectly align due to the shorter gap between cams and crank, so to get timing set perfectly you should use adjustable cam gears. I'm assuming at most they will be a degree or two off, so it may not be very noticeable if you ran without the adjustable cam gears.
Old 03-25-2011, 09:41 AM   #4
El_supracabra
I see what you are saying....hmm...well, wouldnt you be able to "take up" the extra slack with the idler adjustment?
when i put it in time, i rolled it over 360* and it seemed to line back up perfectly. Would that cause it to completely fall on its face at 4000rpm and spit and stumble? It will BARELY make it to 6000. and only if i HOLD it to the floor.
Old 03-25-2011, 09:43 AM   #5
El_supracabra
see the thread "the unfixable mystery problem". lol EXACT SAME problem
thanks!
Old 03-25-2011, 09:52 PM   #6
907mge
907mge's Avatar
I would think that that little amount would not throw off the belt that much. After all it is only 2/100ths of an inch. I would think you probably have another problem.
Old 03-26-2011, 01:14 AM   #7
A non-interference engine is only such as long as the distance between the piston crown and the valves isn't reduced beyond a given point. I don't remember how much room you've got on the 7M before that safety margin is gone.... But, that has absolutely nothing to do with timing.
No, even with slack being pulled up by the idler the timing is still skewed.... You're not removing the slack evenly, just on one side.
BT's right though, the difference is negligible and in most cases not a concern.
Old 03-29-2011, 05:37 AM   #8
El_supracabra
Thanks a lot guys! that is a bit of a relief about my timing. Ill still keep it in mind though...
so far i have Ohm tested the TPS (tested good but needs adjusted), the ISC valve, the MAF, the primary coil, igniter, all 3 pickup coils, the fuel pump relay (for S&G's) and voltage tested all of my VSV's. Im thinking that i may need to replace my fuel injectors or replace my ECU....
Old 03-30-2011, 08:15 PM   #9
El_supracabra
well i swapped out my ECU to no effect. I set the TPS using the feeler gauge/Ohm meter method. And double checked my ignition timing. Everything seems to be fine. Ive noticed some improvement, it doesnt stumble until 4500 rpms now, and runs REALLY strong up to that point. Scary strong actually. LOL
I think there is a serious DEMON under the hood just dying to be released......If i could just figure out this stinking problem!!!!!
anymore suggestions are VERY welcome.....
I think my next step is to replace all of my injectors, my fuel pressure regulator and my coil.
Old 03-30-2011, 09:26 PM   #10
My88isGREAT
My88isGREAT's Avatar
My88isGREAT is on a distinguished road
I had .020" taken off my head and had absolutely no problem. Did you check the timing? You know it idles at the 10 degree mark and not the 0 degree mark right?
My88isGREAT is offline   Reply With Quote
Best Cylinder Head Seal Supra Saiyan MKIII Supra 5 02-06-2011 01:10 AM
torque settings for big end shells and cylinder head johnkarl MKIII Supra 4 11-03-2006 04:01 PM
Cylinder Head?? ZauggIt1 MKIII Supra 8 10-24-2006 01:51 AM
Valve Job On Head Now Car Wont Start? MKIII shujin MKIII Supra 4 08-07-2006 02:16 AM
