Old 03-31-2011, 09:20 PM   #101
ochowdero
yeah definately. ima try to get old rims for that...
anyway i got a question
since im doing the swap...
for the clutch pedal assembly, what do i need to make it work?
have it bolted to the clutch master.. then from the clutch master to the slave right? and itll work?
cause from where i got the pedal set the didnt give me all the bolts. and there is a wire on the pedal set and i dont know where that goes...
thanks for the help,,
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
Old 04-01-2011, 05:49 AM   #102
ochowdero
also the dim wods tried ripping me off.
so now im thinking of getting my auto drive shaft cut down to fit the manual.
what are the pros and cons for doing that?
and if it is ok what are the specs of the manual drive shaft so i can print it out and give it to thhe machanic when i get it cut down..
thanks in advance
i really want turbo
Old 04-01-2011, 06:19 AM   #103
I don't know that you could still use it. You need to find the diameter of the output shaft on each and how many splines are on them first.
Old 04-01-2011, 06:29 AM   #104
ochowdero
i thought you could?
hmmmm, damm idkkkk now
i really want turbo
Old 04-01-2011, 07:24 AM   #105
I don't remember all the differences; It may work and I told you what you need to check.
Old 04-01-2011, 07:59 AM   #106
ochowdero
ok i will,
other than that option, is there any other drive shafts i can use?
i really want turbo
Old 04-01-2011, 06:46 PM   #107
Originally Posted by ochowdero View Post
ok i will,
No. The only other option would be finding a drive shaft with a compatible yoke so a drive shaft shop could cut that off and use it to build a new one.... they can probably get a new yoke anyway though so it's not worth the trouble of finding a used one (and thus a used U joint). The yoke from another W series transmission such as the common W54 may fit too.
Have you tried local salvage yards? Generally the N/A MKIII isn't very uncommon and the drive shaft is a low demand used part from it.
Old 04-02-2011, 07:40 AM   #108
ochowdero
my local pick a part charges 2$ to get in, its not much but i dont like spending that and not finding the parts needed..
also cre, can you look at my clutch pedal?
the first: is up where its spose to be at, but im holding it cause it will just fall back to the floor..
the second: this is when its back to the floor.
i just installed it..
the problem is when i install it, it doesnt stay up like its spose to.. it just goes back as far as it can and then pops down to the floor..
theres no fluid in the clutch master and not hook up to the slave..
its like the pedal isnt adjusted right... and even if i adjusted it to where it would stay where its spose to it will just pop back down to the floor and stay there.. its like theres no tension or something.. idk please help.
i really want turbo
Old 04-03-2011, 02:53 AM   #109
ochowdero
for the clutch pedal, i just figured it will be okay and correct it self when i get the lines hooked up and bleed it..
for my pressure plate bolts, there aftermart (APR OR ARP) and it didnt come with a torque spec, can i just torque them to the standard torque setting for the oe?
i really want turbo
Old 04-03-2011, 05:03 AM   #110
The spring is supposed to assist in returning the pedal but get the master and slave in place before you worry about it.
Yes, the stock spec for the pressure plate is correct.
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
Need transmission removal help ASAP FunWheelDrive MKIII Supra 2 03-23-2008 12:35 AM
