Old 02-19-2010, 07:41 AM   #1
That's a fairly good price actually, IMO. I'm used to hearing closer to $1K, but I've never paid anyone to do a clutch nor have I ever looked up a quote.
The RPM you're seeing sounds about right. With the N/A's 4.30:1 differential its RPM are quite a bit higher than those of a 5 speed GTE with either a 3.91:1 or 3.73:1 diff.
At 3000 RPM on OEM sized tires (properly inflated and all that) you'll be doing 64MPH (yes, your speedo's going to be off a bit ).
Old 02-19-2010, 07:45 AM   #2
91ma70
91ma70's Avatar
91ma70 is on a distinguished road
Thanks alot CRE!
91ma70 is offline   Reply With Quote
Old 02-22-2010, 04:44 AM   #3
suprabahamut
$850 is decent but it does not hurt to check around. Check out transmission places too if you have not. Also if you have big shops like Merchants Tire near you they don't do big jobs like drop transmission and put in clutches but if you ask they might work with you and do it for a cheaper price than a competitor. Thanks what a friend of mine done it was really cheap for him he save around $120 but it was a Honda not a Toyota.
Slipping clutch blues... Supra chick's dad Non-Generation Specific Questions 4 08-20-2007 02:34 PM
slipping clutch kshuping MKIII Supra 2 05-24-2007 03:09 AM
??????New Clutch SLIPPING!!!!!! MKIIISupraTurbo Non-Generation Specific Questions 3 11-24-2005 08:38 PM
Slipping Clutch mrvetten Non-Generation Specific Questions 8 07-07-2005 07:19 PM
