#1 |
Honestly...I would just swap the motor instead of using spray. Nitrous is more of a crutch. If you want big Horse power then you need to take out the 7MGE and put in a 7MGTE or a 1JZ or even a 2JZ. they can make all that Horsepower you want and wont possibly destroy your motor in the process. I have seen many people put nitrous on their car and over do it and melt the pistons. Plus the fact the 7MGE has the same head gasket problem the 7MGTE has and if you blow that you might as well swap much easier. Then if you want nitrous use it on a spray on your intercooler and cool the air going in and then put a purge somewhere and freak people out.
1987 supra NA 5 speed 1JZGTE swap Tokico Illumina 2 and Eibach springs Tokico pillow blocks Suspension Techniques front and rear sway bar HKS super dragger cat-back exhaust plus test pipe Greddy Profec B spec 2 boost controller HKS type 1 turbo timer Supra sport solid steel drive shaft Walboro 255 fuel pump JZA70 Front end mod 18" Volk Racing AV3 18x8.5 front 18x9.5 rear |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Optimal Size | JPDsupra | MKIV Supra | 1 | 06-30-2007 12:39 PM |
| bolt size? | west_side_supra | MKIII Supra | 5 | 04-08-2007 06:18 PM |
| Whats the best catylac converter size | 88Tsupra | MKIII Supra | 6 | 02-09-2007 07:58 AM |
