Old 05-22-2009, 09:31 PM   #1
Clorox9
Clorox9 is on a distinguished road
Default code 24 (cel)
i have a 1987 toyota supra turbo 5spd. I have code 24 for intake air temp sensor circuit short or open. I tested the ohms of the afm it passed. i checked the wiring until it goes inbetween the intake plenum. I have the same voltages from the sensor to the ecu. I even tried using a hair dryer to change ohhms of sensor it still passed. any1 had any similiar problems or ideas. Im leaning towards an ecu.
Clorox9 is offline   Reply With Quote
Old 05-22-2009, 09:58 PM   #2
86.5 7MGE
86.5 7MGE's Avatar
Question
Do you have any noticable symptoms other than the code 24?
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
Old 05-22-2009, 10:43 PM   #3
Clorox9
i have tons. No idle it goes from 350-1200 after a while stalls. it stutters and hesitats all the time once the light is on. sometime it takes til its warm but mostly now its as soon as i start it up. once a little bit of load is applied it just shakes basically rpm drops. feels like someone pulls the wires right off while driving. Feels like its running so lean i got no gas to keep it running. rpm doesnt seem to matter or the gear
Old 05-22-2009, 10:58 PM   #4
86.5 7MGE
86.5 7MGE's Avatar
Talking
I had this problem once on one of my other cars though it turned out that I had to replace the sensors...I would go for that rather then purchasing the ecu besides it would be easier to start out cheaper
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
Old 05-23-2009, 02:29 PM   #5
Clorox9
I was thinking that but its passing and i cant find any of those sensors around the ecu;s are actually cheaper lol
Old 05-23-2009, 03:49 PM   #6
86.5 7MGE
86.5 7MGE's Avatar
You can purchase the sensors from the dealership unfortunately. But the one runs around $200 something.
Cold Air Intake
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Evo Fog Lights
Evo Body Kit
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
code 42 please help baffled cel MKIV Supra 8 03-05-2008 02:28 AM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
