Old 11-28-2007, 07:23 AM   #1
CyFi6
Default How to quickly test starter
Ive got the oh too common starter problem of no crank. When i turn the key to start i hear the relay click, and i hear the starter gear click out to the flywheel and hold in, but no crank. I already fully tested and cleaned the relay and contacts in the relay and it is all fine. I checked all the connections that i can and cleaned the battery terminal connections. I did a load test on the battery and it performed just fine. Sometimes if i click the key to start repeatedly for a bunch of times it will crank, but rather slowly sometimes and inconsistantly, sort or like it stutters a little while its cranking. Sounds kind of like brushes, but i tried tapping the starter with a hammer while trying to crank and got nothing. Ended up having to push start it today.
Anyways my main question is if there is any way i can hook power up to the starter directly from the battery and try cranking without the ignition switch to rule out any of the cars wiring(anything outside the starter itself). I dont want to replace the starter if i dont need to because i read it could be an ignition switch or the long length of wiring going to the passenger side kick panel. ALSO, i did test the clutch safety switch and it worked fine.
Thanks a lot for the help!
Old 11-28-2007, 08:08 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
The large lead and the small wire connected to the starter are both positive. Connect a length of wire to the small wire on the starter (this is a the spade terminal with a brown plastic protective cover) the other end touch the positive terminal on the battery after turning on the ignition. The starter should turn over and start the engine. Remember to insulate the end of the spare wire afterwards if you leave it connected.
Old 11-28-2007, 10:37 PM   #3
f00g00
Yeah mines doing the same thing so I wired a momentary toggle switch from the battery to the small terminal and use that if the key won't start it on the first couple of tries. I mounted the switch in the coin holder through a hole I drilled. This is a temp fix till I do a re-wire and re-location of the starter relay to the engine compartment.
Old 11-29-2007, 12:35 AM   #4
CyFi6
i dont understand why people relocate the relay. If the stock wires go bad why would it work perfect sometimes and not at all other times?
Old 11-30-2007, 01:57 AM   #5
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
^ i have no idea, but doing the relay fixes it forever!!!
Pics of my build.
Do a diagnostic first!
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
90 mkIII starter connections doodah MKIII Supra 1 11-11-2008 06:14 PM
starter removel? swied MKIII Supra 4 04-23-2007 04:50 AM
Emissions Test Info in "Your" Area/State mrnickleye Off Topic Forum 9 05-01-2006 01:11 AM
Starter Problem dcrusupra MKIII Supra 1 01-20-2006 01:34 AM
