Old 05-08-2012, 12:59 AM   #1
worm611
worm611 is on a distinguished road
This is the fan setup I run, and a lot of people on yellowbullet forums run it as well. It fits my aluminum radiator fine, but not sure about the stock one.
http://www.summitracing.com/parts/RNB-620-104/?rtype=10
worm611 is offline   Reply With Quote
Old 05-08-2012, 04:33 AM   #2
floridamtbiker99
floridamtbiker99 is on a distinguished road
Default Thank you worm611. advice little to late.
I just install the 14" electric fan for $67 That was easy. The hardest part was removing the clutch fan.
I talked the parts guy I trust at the Advance auto parts, he told I can still put a 10" on my car with relays for both fans. If realy need it.
If I am not racing, one fan should work very well.
The 14" is used on some small v8's. Therefore it should work for you inline 6 cyclinder.
I still have to put the external thermostate for the fan on.
I keep the stock shroud on.
Thank you so far for your imput.
I will let you know in a couple days how well it works in the Florida heat.
floridamtbiker99 is offline   Reply With Quote
Old 05-14-2012, 10:05 AM   #3
floridamtbiker99
Default The Aluminun radiator for the summit fan..
Where did you get the Aluminum radiator at and what is the cost.
There is another opition for me, is to put another 10 fan on my radiator. but I will lose the shroud.
I will be waiting for you comments or/and your advice.
Thank you.
I need this car running so for college.
Old 05-14-2012, 12:53 PM   #4
i take it the new fans didnt help??
if your interested in an aluminum rad. check out the link in post#4
im going to run the griffan rad and fans for my 1uz.
Electric fan relay Paul_NJ MKIII Supra 3 07-25-2010 05:04 PM
Electric Fan? mkiiisupra MKIII Supra 24 06-18-2010 08:26 PM
Electric Fan Controller Temp. question SilenceboneSupra MKIII Supra 19 06-16-2010 08:27 PM
Pulling ICE and related parts and GOING ELECTRIC ddmcse MKIII Supra 6 12-11-2008 09:40 PM
Help on electric seat supratrd654 Non-Generation Specific Questions 1 03-14-2005 07:12 AM
