Old 05-08-2012, 04:33 AM   #2
floridamtbiker99
floridamtbiker99 is on a distinguished road
Default Thank you worm611. advice little to late.
I just install the 14" electric fan for $67 That was easy. The hardest part was removing the clutch fan.
I talked the parts guy I trust at the Advance auto parts, he told I can still put a 10" on my car with relays for both fans. If realy need it.
If I am not racing, one fan should work very well.
The 14" is used on some small v8's. Therefore it should work for you inline 6 cyclinder.
I still have to put the external thermostate for the fan on.
I keep the stock shroud on.
Thank you so far for your imput.
I will let you know in a couple days how well it works in the Florida heat.
floridamtbiker99 is offline   Reply With Quote
