Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 12-31-2008, 09:36 PM   #3
supkar
supkar is on a distinguished road
Or, pull the return line to the pump reservoir and put it in gallon jug. With a friend slowly pouring ATF into the reservoir, run the motor till old fluid is completely flushed out. Install hose, fill with new fluid and run engine while cranking steering wheel all the way to the left , then right. Repeat this till air stops bubbling up from the reservoir. I like to jack up the front for this last step to make it easier.
supkar is offline   Reply With Quote
Power Steering?!? Boombastic Drifting 5 05-19-2009 04:19 AM
Power Steering Pump and Fluid Chambers MKIII Supra 8 06-29-2008 03:59 PM
Power steering pump carfanatic89 MKIII Supra 1 09-15-2007 04:16 AM
Power steering fault david small Non-Generation Specific Questions 1 09-20-2006 12:41 AM
