Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 07-19-2006, 02:17 AM   #21
do a diagnostic lol
and no gas caps aren't connected to the check engine light
let me know if you are having trouble doing a diagnostic and i will run thru it in pm step by step for you
Old 07-19-2006, 03:18 PM   #22
Isphius
Isphius's Avatar
I was just wondering, Is there anything else usefull to do with these ports? There is a bunch of em, Or did they just do that to prevent us from doing our own diagnostic when the car was new? haha. I also got code 11, And i had my ground battery terminal come off, But i fixed that. Could it just be stored from that?
Old 07-20-2006, 12:57 AM   #23
yep from the ground cable
FP and B+ runs the fuel pump at 12v when ign is on
some cars have ect in theirs so you do ect & e1 = trans diagnostic
can't think of the rest for now lol
Old 10-03-2006, 08:52 PM   #24
Rob420
Rob420 is on a distinguished road
Default Thanks Suppra girl
I am gonna try the diannostics now! I also have done a tune up and helped but did not fix the problem.
Rob420 is offline   Reply With Quote
Old 10-17-2006, 12:46 AM   #25
khills
khills is on a distinguished road
ok, i finally figured it out, took me like..10 mins haha so lame its been 3 months.
ok so its a 42...WHICH makes sense, cause my speedometer doesnt work, when i bought the car, the previous owner thought it was a speedo cable..but i guess not.
does anyone know if the sensor is in the transmission or is it behind the dash? what is a good way to test the sensor to make sure?
khills is offline   Reply With Quote
Old 12-09-2006, 08:34 PM   #26
chrisluvsmarkrad
chrisluvsmarkrad is on a distinguished road
Did you get the trans. sensor issue straightened out yet? If not, I can help you.
chrisluvsmarkrad is offline   Reply With Quote
Old 12-12-2006, 06:35 PM   #27
redmaro
I want to do a diagnostic but I dont know which ports I have to bridge. A pic would be helpful. And also how do you know what code number you getting. For example code 24 will blink 24 times?
MK3, Auto, Turbo.
Old 12-12-2006, 07:03 PM   #28
Isphius
Isphius's Avatar
the pins you jump (t1 and e1) are pretty clearly marked on the cover to the diagnostic thing. Ones in the middle and ones on the top right. Code 24 will blink 2 and then 4 times. Like ...o.o...o.o.o.o...
Old 12-12-2006, 07:11 PM   #29
redmaro
Smile
I know its e1 and t1 but, where is it on the diagnostic thing. My diagnostic thing dosent have a cover.
MK3, Auto, Turbo.
Old 12-23-2006, 04:00 AM   #30
Monkey
Monkey is on a distinguished road
Originally Posted by suprra_girl
yep... ppl have used paper clips
that white gunk is used to keep the terminals in good health i believe
That white gunk is waterproofing/dielectric grease that helps keep water out of electrical connections, and it also helps to promote electrical conductivity.
Monkey is offline   Reply With Quote
Did a diagnostic. redmaro MKIII Supra 5 02-04-2007 04:43 AM
diagnostic scanner sd88supra MKIII Supra 1 12-08-2006 03:38 AM
1995 Supra EGR Diagnostic??? johnlijo Non-Generation Specific Questions 1 02-26-2006 10:18 PM
