Go Back   Toyota Supra Forums! Join the Supra forum! > General Discussions > Supra FAQ
Old 12-30-2004, 07:11 PM   #1
smithen999
smithen999 is on a distinguished road
I have 1993 supra 3.0 non turbo (manual 5-spd), whilst driving at a steady 60 mph on the motorway, the warning triangle and engine management warning light illuminated, I immediately stopped, switched it off, then restarted and it was ok, but this repeated itself 3 times. following this, the engine cut out without any warning, with no warning lights. The fuel consumption prior to this fault was noticeably increased.
if anyone has any clues please let me know.
many thanks in advance smithen999
smithen999 is offline   Reply With Quote
Old 12-30-2004, 11:38 PM   #2
hey
have you done a diagnostic yet?
jumper te1 & e1 in the diagnostic box and switch ur ignition on and count the flashes
i would assume mk3 & mk4 are the same
try that and see what ya get and we'll work from there
Old 01-01-2005, 01:06 PM   #3
smithen999
Hey,
Did this, and the engine management light flashes multiples of 4 - 2.
thanx.
Old 01-01-2005, 02:38 PM   #4
ok so it flashed like this?
flash, flash, flash, flash,,, flash, flash?
if so that's code 42 which is speed sensor signal, does ur speedo work?
Old 01-01-2005, 02:56 PM   #5
smithen999
yeah thats it. speedos working fine, it hasn't been converted to mph either.
Old 02-12-2005, 07:16 AM   #6
i'm currently hooking up with some mk4 owners so shall have some good info for you soon
Old 02-13-2005, 03:10 AM   #7
300hpvision
300hpvision is on a distinguished road
jump your supra into a dyno and c what happens. if u cant solve it get a pro that can
HELP ME FIND A STOCK SUPRA DAMN IT!!!
300hpvision is offline   Reply With Quote
Old 02-13-2005, 03:14 AM   #8
a dyno will not make any difference to the outcome of his problem...
also have you got a speed cut defencer in there?
what do you mean when you said you haven't converted it to mph yet? where in the world are you?
Old 02-19-2005, 04:34 AM   #9
300hpvision
the dyno will allow u to go at high speeds so u can check if anything goes rong. its not 2 solve problems its 2 find them
Old 02-19-2005, 06:07 AM   #10
please
he has a check engine light coming on and you suggest he goes and rapes it on a dyno
if he has one of his speed sensors not connected properly or is not sending the required information vital signals are lost to the ecu and therefore dangerous things can happen
cel problems do not require high speeds or high throttle solutions
Engine Management For VVT-i JDM Supra? Mellowdien MKIV Supra 3 10-19-2008 04:00 PM
Help Me Please, Why Does My Engine Management Light Come On After 80mph mohamed MKIV Supra 0 03-15-2007 07:06 PM
engine management light johnkarl Non-Generation Specific Questions 0 01-04-2007 10:25 AM
orange engine management light?? star Non-Generation Specific Questions 5 08-14-2006 09:31 PM
