Old 12-05-2006, 01:15 PM   #1
scruffboy
scruffboy's Avatar
Default Coolant Temperature Sensor
I found out why my Check Engine light came on. (see posts below) Bill UK told me to pull the EFI 15, so I read up on that and found out it holds codes. I don’t own a diagnostic machine, but I started reading what the codes could be and started checking them off while under the hood. It didn’t take long to find what was wrong. The Coolant Temperature Sensor was broke, the plastic female end. I used some airplane glue to put it back together for now. From what I can see, it looks like it screws into the rear thermostat housing. Am I correct, or will I have to replace the whole rear thermo housing? Has anybody out there ever have this problem before.
Thanks,
Scruffboy
Heater Union (Coolant Leak) slader99 MKIII Supra 11 12-28-2009 12:29 AM
Water temperature sensor question! SilenceboneSupra MKIII Supra 3 09-08-2009 05:04 PM
Coolant temp sensor thread size?? petey turbo MKIII Supra 5 02-12-2007 06:15 PM
Coolant temperature? IHateHacks MKIII Supra 2 06-15-2006 12:40 PM
Knock sensor for an N/A. rnoswal MKIII Supra 2 11-16-2005 05:12 PM
