Old 11-04-2006, 04:28 AM   #1
stevenr816
stevenr816 is on a distinguished road
Default help,no spark
i just bought a 87 supra non turbo. the car has good compression, timing, distributor cap and rotor, spark plug wires, spark plugs and coil. if i take off the coil wire and put it next to ground it sparks only once when you crank it. and then stops and doesnt do it again until you crank it again. and thing on what it can be?
im pretty sure its not the coil because i have 3 of them and they all do the same thing. all the fuses are good.
thanks
steven
stevenr816 is offline   Reply With Quote
No spark issues DDBT MKII Supra 2 01-06-2009 07:08 AM
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
