Old 10-04-2004, 04:59 AM   #12
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
hey welcome to our friendly little board
i'm using the toyota stock turbo ct26 but with an upgraded to4e wheel in it which is 50.9mm known as the 46trim i believe
the stock intercoolers have been proven to hold 15psi but you NEED to replace the factory intercooler plumbing as it is very restrictive.. i think if you replace it all with 2" plumbing you'll be away
the problem with 7mgte factory intercooler plumbing is on the turbo outlet as it comes to the bend for the intercooler pipe there is a sharp 90 degree bend which shrinks to a terrible inside diameter
the other is the factory plumbing thru the guard also squishes down and on the exit coming to the strut tower it also shrinks then opens up again to the 3000pipe.. which the entry on the 3000 pipe is 2 1/4 inch or something then it expands to 3"
so i would replace all your plumbing with the same size all the way and also get an aftermarket pipe to replace the 3000pipe.. HKS do one or you could just do your own
you should now be holding boost happily
and thanks for the congrats
Pics of my build.
Do a diagnostic first!
MKIII on PINKS reminder today! ravenmaster MKIII Supra 1 03-20-2008 01:38 AM
My Supra died today :( Sinistral MKIII Supra 3 01-22-2008 12:58 AM
got my 1990 Supra Turbo Today! Slofo MKIII Supra 3 12-19-2007 05:03 PM
Lost control of my car today. redmaro Off Topic Forum 5 01-19-2007 05:04 PM
Buying one today.. jimwww MKIII Supra 3 01-27-2006 04:33 PM
