Old 10-03-2006, 11:31 PM   #1
the#1
the#1's Avatar
the#1 is on a distinguished road
Default My 1st post! - Siezed 4M-E, Crunched Oil Pan... Related?
Hi all, I'm very glad to have found a nice active forum on Supras!
Anyway, I have an '81 Supra auto and the 4M-E is siezed SOLID. No clunking back and forth, like if it were stuck camshaft or stuck pistons. It must be the crank that is stuck. I have put a lot of force on the crank snout bolt with a long breaker bar, and succeeded in loosening the bolt, but NO movement whatsoever.
And the oil pan is badly crunched in, like someone jumped onto a rock or something.
So my thoughts are that maybe the oil pan is contacting the crank lobes, preventing any movement. Could that be possible?
I'm almost ready to start tearing out the steering stuff to get the oil pan off, but I need some ramps first. Or maybe I'll just set it up on tires.
I only paid $400 for this car, and I absolutely love it. I can't wait for the day I get to start her, and drive her!
the#1 is offline   Reply With Quote
Old 10-04-2006, 04:38 PM   #2
Supra2NR
Supra2NR's Avatar
is that a mk1?
never seen one b4
it looks nice for a car that old
hope you get all the help you need in here
and hope you get it runnung soon
and welcome to the forum too
Old 10-04-2006, 05:33 PM   #3
dcrusupra
dcrusupra's Avatar
Let me start by saying thats a nice MK I.
Now down to the problem. It is very possible that the oil pan is hitting the crank. But the dent would have to be very deep for it to do that. Did you check the oil level in the car? I guess you're going to have to take off the oil pan to see if that was the problem. Either way, if it seized you're going to need a new engine. So might as well take it out instead of taking off the steering components.
New Rebuild
My CarDomain
Old 10-04-2006, 08:18 PM   #4
the#1
the#1's Avatar
Thanks for the compliments on the beautifull MKI.
So I would need to replace the engine, even if it's just the oil pan siezing the crank? I figured that if that was the case, I could just replace the oil pan, and call it good (till she blows up!)
And thanks for the warm welcome! I'm sure I'm here to stay!!!
---Reuben
Old 10-04-2006, 09:35 PM   #5
dcrusupra
dcrusupra's Avatar
Well, keep in mind, I haven't seen the dent so that might be the cause, lol. Either way, I wouldnt start messing with steering components. I, personally, would never mess with that. I would rather pull the engine than to start taking apart the steering stuff. It would be easier anyway.
New Rebuild
My CarDomain
Old 10-05-2006, 08:05 AM   #6
i would sayy.. more than likely.. someone slipped off the crossmember with the jack and that is what munched the oil pan
by munching the oil pan the oil pump pickup & mesh has broken and cracked and left many shards of metal in the oil, then that nice metal filled oil has gone through the motor and shagged out the bearings and got dam hot therefore seizing the engine
well that's my theory anyway, be interested if you tear it down to see what you find
and yes awesome mk1 you have there
Post YOUR Supra.. the one you presently own or have in the past. tsupra89 MKIII Supra 120 02-27-2018 07:38 AM
How to post pics scruffboy Non-Generation Specific Questions 3 07-05-2007 09:32 PM
Using the Forum suprra_girl Non-Generation Specific Questions 0 04-17-2005 02:12 PM
