Old 09-27-2006, 09:01 PM   #1
Rob420
Rob420 is on a distinguished road
Default Help PLEASE Supra Wizards!!!!
I need to know if you can test a Max air flow sensor?What does the car do when they are going bad?
See, My car (a 1987 According to the title) With a 7M-GE seems to run good till you run it hard.Then what seemed good gets blown away because it suddenly kinda like cutting out but is actually getting more power.No Turbo for those who had that answer.
It runs pretty good over all. When I accelerate hard it seems that something opens or kicks in thats not normally there. but does not happen suddenly. Its almost like it has a miss and gets better. Its sputtering but getting stronger with each little stutter.
Rob420 is offline   Reply With Quote
Old 09-28-2006, 05:09 AM   #2
Whoops, hit edit on your post instead of quote.
Please state your concern/question in different words so I can follow you.
Old 10-01-2006, 05:07 AM   #3
i would do a diagnostic first, read your codes then post them here
2nd: the best place on earth for the supra learning and diagnosis... www.cygnusx1.net/supra
Old 10-01-2006, 06:48 AM   #4
Ok, so it sounds like you may have a misfire. Spark plugs, wires, cap and rotor.
It may also be a partially plugged fuel filter.
All of these is easy & cheap to change.
If it still acts the same, fuel pressure too low, or dirty injectors.
Puts 2 cans of TECHRON in a full tank and drive, to help clean injectors. See if it improves.
Old 10-03-2006, 09:09 PM   #5
Rob420
Default I need a little help with diagnosis please!
I got three codes, It seems the ECU is a common link to all three. So I gues Thats where I will start!
Old 10-03-2006, 09:10 PM   #6
Rob420
Default Oh yeah
Codes #24,41,51
