Old 08-31-2006, 02:39 AM   #1
bhansen42
bhansen42 is on a distinguished road
Default many problems; Worth fixing?
87 Supra Turbo
108k
no snow
no salt
stored winters
body good
seats bad, needs seats: ching ching ching ,any suggestions?
probable water pump failure :ching ching ching
coolant leaks around head, bhg? :ching ching ching
coolant leak around turbo: ching ching ching
smokes on start up only,poor sealing valve guides?: ching ching ching
no other repairs to vehicle
Is repair worth expense, i.e., what kind of additional mileage may I expect? Any thoughts appreciated.
PS: Are you suffering poor manual shifting? add Lucas to trans and it will disappear.
Thanks, Brian
bhansen42 is offline   Reply With Quote
Old 08-31-2006, 08:43 AM   #2
Supra2NR
Supra2NR's Avatar
its a turbo and the engine is still has a running engine
is it usdm?
i had a hard time looking for a usdm 7m turbo in here, still havent found one that even close enuff to get
get the hg replaced with a metal one
get you machines head
retorqued
you might get another 100k out of that motor
Old 08-31-2006, 08:58 PM   #3
Isphius
Isphius's Avatar
The MHG us ynneccesary for stock. The stock toyota HG will hold up to a lot of boost, for a long time. The important part is keeping the motor cool, not overheated, proper torque on the bolts, And good gas. A stock toyota headgasket and arp studs torques to 110 ft lbs will hold up to 350 rwhp, And maybe more. Detonation is what kills the headgasket. And yes, Once the repairs are done, You wont need any work for a long time. Itll be good for a while.
Should i buy this supra? it needs some fixing Krazay MKIII Supra 1 11-12-2007 03:32 AM
