Old 03-06-2005, 06:43 PM   #1
DEVILDOG
DEVILDOG is on a distinguished road
WHAT DO YOU THINK THE CAUSE IS . I READ CHILTON SVC MANUAL ON T.S . AND THIS WASN'T IN THE CHART. THE IDLE ONCE THE CAR IS WARMED UP 800 RPM . ALTHOUGH THE ODOR OF FUEL IS STRONG.
DEVILDOG is offline   Reply With Quote
Old 03-08-2005, 12:17 AM   #2
snafu54
snafu54 is on a distinguished road
check for clogged/borken gas lines or lose hoses for the fuel smell.check for a broken/cracked vacuum line for the low rpm.
snafu54 is offline   Reply With Quote
Old 03-14-2005, 06:57 AM   #3
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
is it a burnt exhaust smell or fresh fuel smell?
are the vacuum pipes on the charcoal cannister or leaking? generally leaking vacuum lines will cause the idle to rise a little bit
Pics of my build.
Do a diagnostic first!
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
Removing carbon canister, fuel evap. emissions pdogg Non-Generation Specific Questions 2 09-17-2008 06:58 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
Questions about the oem fuel system Magical Trevor MKIV FAQ 7 08-19-2007 04:40 PM
tein flex or fuel system west_side_supra MKIII Supra 8 04-22-2007 11:01 PM
