Old 04-14-2006, 02:18 AM   #1
newtome
newtome is on a distinguished road
Unhappy Need help with Code 51
Hi
I'm getting a code 51 when I step on the gas and when I let it off the code goes away.I can't drive the car at all it goes into save mode.Ita a 89 supra turbo.The throttle position senser tests out good.I'm lost and ready to pull the rest of the little hair I have left out.Any help would be great.Thanks
newtome is offline   Reply With Quote
Old 04-14-2006, 04:04 AM   #2
joel w
joel w's Avatar
Did you remove the diagnostic jumper(paper clip) under the hood from the diagnostic block when you last checked codes?
Old 04-14-2006, 01:36 PM   #3
newtome
I've pulled the fuse to reset the ecu and started the car and it runs the same I've done it with the jumper and with out the jumper and it does the same.with the jumper in it will flash code 51 only when I try and give it gas and when I let off code 51 goes away.
Old 04-14-2006, 03:05 PM   #4
joel w
joel w's Avatar
I would try to adjust your TPS as per the TSRM on page FI-103 and see if that makes it go away..
http://groundsky.co.nz/techinfo/TSRM/07_FI.pdf
Old 04-14-2006, 04:22 PM   #5
newtome
I've done that three or four times and it is still the same.I've checked the tps with the ohm meter also and it shows its good.I've checked the wires all the way back to the ecu just to make sure that they were good also.
Old 04-14-2006, 07:30 PM   #6
joel w
joel w's Avatar
pm sent..
Old 04-15-2006, 11:45 PM   #7
Cool
vsv switches under the intake
i had the same problem last summer
you're probably eating gas like candy too
there is a switch for fuel and a switch for egr
check em for continuity ohm resistance is 30-50 ohms
page FI-99 and FI-98 service manual
Old 04-17-2006, 06:06 PM   #8
joel w
joel w's Avatar
Take a read through this thread as it is the best possible explanation I have heard yet to date... hope it helps..
http://www.supramania.com/forums/showthread.php?t=16887
KS code, and no KS connector? Scionguy MKIII Supra 5 08-28-2008 08:15 PM
code 14 and 52 west_side_supra MKIII Supra 30 06-02-2008 05:04 PM
Where EXACTLY is the key code? finaltable MKIII Supra 6 08-12-2007 01:26 AM
still the getting code 52 whitequasimodo MKIII Supra 9 11-17-2006 12:34 AM
getting wierd error code and need general advice please noredline MKIII Supra 7 10-01-2006 05:23 AM
