Old 01-27-2006, 03:49 AM   #1
TxSpeedBoy
TxSpeedBoy's Avatar
TxSpeedBoy is on a distinguished road
Default Oil around the spark plugs!!!
I have oil around the spark plugs, and I was messing with it today trying to bolt back down the thing on top of the head with all the wires and suddenly it won't start now. It does everything but roll over. The starting sounds the same, but just can't get it to roll over. I was thinking about just cleaning out the area around the spark plugs and seeing if that works. But not sure how the oil got there. I think it's due to the bhg, but I am think it's more like the valve cover gasket? Any idea on how to fix my situation?
Supra Project 06... 1987 Turbo.
18" Enkei RS5. K&N Filter. Magnaflow custom exhaust.
"I got a pair of subs for my girlfriend...Good traid huh?!
TxSpeedBoy is offline   Reply With Quote
Old 01-27-2006, 04:52 AM   #2
mrnickleye
mrnickleye's Avatar
Wink The answer is out there
Ok t-boy. You've been here long enough now, so....here is the answer to this, and many more questions you'll have...
In the General Questions section, and the other sections too, over to the right, in a blue bar, you will find different links. Click the one that says 'search'. Then type in some of the words of your question, and click 'enter'.
Several threads will come up that pertain to those words.
I did...'oil spark plug'...and this came up.
http://www.toyota-supra.info/forums/...ght=spark+plug
this method will usually get you answers faster than asking in a new thread, because most of the problems have already happened to members, and the answers are posted in some thread on this site.
Now when you say it 'rolls over', do you mean it cranks, but won't start??
Old 01-27-2006, 09:32 AM   #3
TxSpeedBoy
TxSpeedBoy's Avatar
yes, that is what I mean, and you are right. I'll start using that search tool. Sorry bout' that.
Old 01-27-2006, 08:58 PM   #4
mrnickleye
mrnickleye's Avatar
If there is a bunch of oil down those sparkplug boot holes, it can ground out the spark, thus not let the plug fire.
I took some old pillow cases (because they are thin material) an a screwdriver and 'mopped' up the oil. That way it all did not go into the cylinder when i removed the plugs.
A new set of wires is about $100 at carquest. You may just need to remove them and clean them with brake cleaner spray.
VC gaskets is why oil gets in the holes. The center gasket is a dealer item for approx $40. it is not mandatory that you replace it, as it is there to keep debri out.
Old 01-28-2006, 02:50 AM   #5
TxSpeedBoy
TxSpeedBoy's Avatar
You may have just saved my life, thank you very much. If we were drunk, I would simply say, "I love you man". But we aren't, so a simple thanks in order. A bIG thanks.
Old 01-28-2006, 07:04 PM   #6
TxSpeedBoy
TxSpeedBoy's Avatar
ok, I just got through cleaning the valey out and around the spark plugs, I couldn't take the plugs out because I don't have extention I need. But the car still won't start. Same thing, cranks ok, but won't start up. So I'll get the extention tomarrow and pull em' out and clean em' up. But if this doesn't work, could there be anything else. I mean this just happened over night, so I don't think it's the timing. Any clues?
Old 01-30-2006, 09:51 PM   #7
TxSpeedBoy
TxSpeedBoy's Avatar
Success!!!! She started today with alot of oil-burnt smoke coming out of the rear, she purred furiously.
I cleaned the valey, the spark plug holes, and cleaned the spark plugs with engine degreaser. Put everything back together and vuala! Thanks for all the help MRNICKLEYE.
Old 02-01-2006, 01:56 AM   #8
mrnickleye
mrnickleye's Avatar
Good to know your on the road again.
Old 02-01-2006, 05:46 AM   #9
TxSpeedBoy
TxSpeedBoy's Avatar
thanks, I appreciate it.
Spark Plugs (1G-GE vs 7M-GE) makemedie Non-Generation Specific Questions 5 10-26-2008 05:19 AM
NGK Spark Plugs 91 Supra MKIII Supra 5 08-07-2007 03:52 AM
1986.5 with blown Head Gasket - Removing Spark Plugs unkymurch Non-Generation Specific Questions 10 03-02-2007 06:48 PM
Issues After Changing Spark Plugs Getphazed MKIII Supra 8 11-03-2006 12:31 PM
Spark plugs & WIRES HEMAN MKIII Supra 2 11-03-2006 05:31 AM
